And TIG is way way more difficult to master
My S2 coupe bit of a rebuild and repair thread.
What I'm figuring out more and more with this car is take what you have a repair or adapt it. With that comes a world or pain and a welder. I've already sent a couple of bit away for alloy welding and even though the price is cheap enough, I'm having to wait 2 weeks and then there is the cost of travel etc. So having your own kit makes sense. Sure I'm going to need practice welding more, but if you mess it up most times you can just grind it back and start again. Looking at some of the r-tech welders a while back and they were around the £1K mark for a AC/DC welder.
I was tempted by the R-tech. I like Trev's blog and he rates them.
However, last year I did evening classes at my local college and got qualified to weld. No matter how much practice, I struggled to master the TIGNothelle S2 Avant
I was thinking about looking at doing some night classes, need to have a look around in the new year. Years ago (30) I did my apprenticeship at ICI there I learned to stick weld, and many other useful skills, but a lot of them have just been forgotten as career move to a different path.
Originally posted by Tractor Dave View PostAnd TIG is way way more difficult to master
I got taught to weld and braze with just oxyacetylene as well as Arc in collage, though it's been so long since learning I've pretty much forgotten how to do it as I adapted to using a MIG as soon as I started working.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
I have an R-Tech 160 AC/DC rig with a decent torch. If you want to try your hand at it, you are welcome to come and spend a few hours playing with it. The Argon is a bit expensive but consumables are cheap. I'm in Bristol and Tea and coffee are included. I've used it to make my exhaust and inlet tubing along with lots of little bits and pieces.91 Modded 3B
14 A6 Avant Black Edition
Thanks that would be helpful. I'm not intending to order one just yet, as I've got hundreds of other pounds to spend on other more urgent parts & tools. I'm hoping when the weather improves around April next year then I'll start looking around for a machine and if the car is running by then take a road trip
Look at the hobby weld gas range and use that with your current welder and get some new wire until you upgrade.
I used 5% argon / co2 mix for the first time last year after having only co2 for years... I was amazed by the difference in cleanliness and lack of splatter. Co2 from a pub was very very cheap but offset by cleaning up costs and overall satisfaction so overall the the hobbyweld 5 is a better deal for me and compliments my amateur welding.You do not have permission to view this gallery.
This gallery has 1 photos.
- 1 like
Thanks, I think gas is the way to go. However I'm not 100% sure I want to invest any money in this welder, as I would need the gas, wire, pipework and regulator, and I don't even know if the gas side of the welder works, could be faulty. I think I'm now done with welding for the front-end when I get to the rear I'll see what is required and it it needs work then a new welder will be purchased.
I pay £40 (for cash or. 50 with card) for hobby weld 5 from a welding supplies place. The sort of useful indutrial estate unit that only does 1 thing but really well. I got a new welder from there recently as well and they offer in field service should it ever go wrong. The regulator I got was £25 but a decent one gives better control and with 2 gauges, it tells me how much flow i have as well as how much is left in tue bottle.
They normally give an idea of how long a bottle will last at 9l/min flow rate -I'm sure you can ask whoever is selling it. 10l is still quite small, but even at that price WAAAAAAY cheaper than the disposable bottles you can get.
Careful on fill pressures, some are much lower than others.
- 1 like
Originally posted by Bowie69 View PostTig is lovely for fabrication,, but mig way better for car bodywork.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
- 1 like
Originally posted by B5NUT View PostThanks, I think gas is the way to go. However I'm not 100% sure I want to invest any money in this welder, as I would need the gas, wire, pipework and regulator, and I don't even know if the gas side of the welder works, could be faulty. I think I'm now done with welding for the front-end when I get to the rear I'll see what is required and it it needs work then a new welder will be purchased.
I have a 30L bottle of Argoshield light which is mostly Argon, 93% if remember correctly and what's recommended for car body work, produce's super clean welds even if you can't get the work piece perfectly clean. I paid a deposit of about £40 for the for the bottle and the first fill cost £35, with several future fill's costing much the same, think the last fill cost £37.50 three years ago. That's from my local welding sundries supplier, a guy I've know all my life who also sold my regulator for £30, quite a nice one with two gauges.
I also invested in Euro torch conversion kit to update the machine which cost about £70 for something of decent quality, though most second hand welders that have had serious use will probably already have been updated by now.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
