My S2 coupe bit of a rebuild and repair thread.
  • Bowie69
    • Nov 2013
    • 2675
    At least it'll be easier to get off
    Honestly though, I fitted a new pump a while back and found it really hard work to get that ring round to the right place, either the gasket or something was making the whole thing appear thicker.
    • SteveH
      • 4460
      Originally posted by B5NUT
      A single picture that captures the quality of the work done to this car in the past. Half arsed, half finished, half a job, that'll do.
      Sums my car up nicely
      At least it's not mangled with chisel marks
      91 Modded 3B
      14 A6 Avant Black Edition
      • B5NUT
        • Sep 2021
        • 1071
        Look at the scratches around the tank, screwdrivers have been in there..
        • SteveH
          • 4460
          Looks like they tried to pry it off based on the scratches
          91 Modded 3B
          • B5NUT
            • Sep 2021
            • 1071
            O it was easy to get off, required very little effort. For an individual to have trouble to get it back on then I understand, and hopefully they would take the car to a garage so they can put it on tight, but for a so called professional garage to this level of workmanship is, well I just don't have the words (not ones I can write on this forum). thankfully it's all been removed. Now need to buy pipe & tools. O well it's only money!
            • Mikes2
              • 1704
              Some of the diff mounts have an arrow on the rubber for direction of travel. Bottom left of the 4, is the usual orientation
              Mike
              http://www.s2-audi.co.uk
              • jp_paul
                • Aug 2010
                • 92
                Ahh ****** - that means I put mine in wrong 8 years ago. I assumed the arrow pointed up I’ll get a meyle one put in whilst the diff is off.
                Man, I love this forum
                • B5NUT
                  • Sep 2021
                  • 1071
                  So had a look at the bush this evening and it does have an arrow. So bottom left on my image is the correct orientation.
                  • Jaswan
                    • Apr 2011
                    • 771
                    #279
                    I put a "black" powerflex or whatever in mine and Iv no idea what way it went in! ?
                    Surely I looked at the one I removed!
                    I will have to take a look.
                    • Jaswan
                      • Apr 2011
                      • 771
                      #280
                      Just googled it and it looks like the hole is centered!
                      And could the fuel smell been from the sending unit not being fully tightened?
                      Jase.
                      • B5NUT
                        • Sep 2021
                        • 1071
                        So a little update on my progress. But first a quick question, does this cover look OK or has something hit it and bent it? It's the one that goes on the rear output of the gearbox.
                        So over the last few days I started work on the underside of the car, and rust wise it's not that bad. There are a few patches of rust on some of the edges but nothing major & no holes which is a bonus.
                        So far I have spent about 3 days under the car, washing it first then going over it and removing the rattle can underseal that has been sprayed on.
                        Rear wheel arches are also in excellent condition.
                        While under the car I kept getting a smell of fuel, I've got the tank out and that is dry and no damage. So it's got to be down to the bodged pipe work. It's a mixture of old and new so I'm looking to replace the lot.
                        Not sure what is going on here
                        Looks like they were having trouble refitting clips as a few have been bodged
                        The fuel line coming from the tank going to the filter is original and looks to be in good condition, however the line come off the filter is not in a very good condition and needs to be replaced. I also want to get rid of as many joints as possible.
                        Also got the subframe back from the blasters. It was in good condition except for the offside ARB mount. So got out the grinder, purchased some 2mm steel sheet and hoped it was going to go well! Started of by cutting what was left of the cover off, then welding in 2mm steel to strengthen a couple of area's.
                        Next replaced what was left of this captive nut
                        Finally put a new a new cover over it.
                        Other side was was ok just a bit thin in a couple of area's on the cover so welded in some new steel.
                        With the steel being so pot marked due to the rust hopefully no one with notice the pot marks left by my welding
                        Also started on the diff seals. One done so far and the seal was a complete sod to remove, I just know the other 2 are going to be as bad.
                        • Jaswan
                          • Apr 2011
                          • 771
                          #282
                          I don't think my gearbox has that cover but it certainly looks bent to me.
                          Great update, looks like it's going to be best to replace the fuel lines with new hard line.
                          Jase.
                          • SteveH
                            • 4460
                            I've not seen the output shaft cover. The 3B 5-speed box doesn't have it and I've not seen it on the 6 speed boxes I've had. If it's bent chuck it.
                            91 Modded 3B
                              • Dec 2017
                              • 5992
                              Mine has the cover. I suppose it is designed to protect the joint from heat from the exhaust and stop the grease from drying up. As my joint grease is very dry, it's not doing that good a job.
                              If you can bend it straight, I would still keep it.
                              • B5NUT
                                • Sep 2021
                                • 1071
                                So I did not make myself very clear in respect to the cover. What I was trying to say was, should the left side follow the same curve that the right has?
