My S2 coupe bit of a rebuild and repair thread.
  • Bowie69
    • Nov 2013
    • 2675
    Its a bit of a pig to get .... but yes rubber better than poly in this location.
    • johne
      • Apr 2007
      • 1405
      When fitting, I do remember having to think about the orientation of the bush before pushing it into it's aluminium housing so that the diff would still stay level wherever the bush bolt engaged in the elongated slot in the mounting and still line up.
      • Bowie69
        • Nov 2013
        • 2675
        Agreed, orientation matters, check against the poly bush if it is still in there....
        • B5NUT
          • Sep 2021
          • 1071
          It was the original OEM bush that was fitted which has a centre hole. However I found this image from a thread back in 2103, so will press it in as highlighted unless someone knows any different.
          • Bowie69
            • Nov 2013
            • 2675
            From memory that looks right
            • B5NUT
              • Sep 2021
              • 1071
              Wonder if someone could provide any help with this. Tomorrow I'm going to remove the fuel tank from the car along with the fuel lines, as some one has made a right bodged job when replacement lines were fitted. Also removing them as while I've been under the car today, I smelt fuel on a few occasions. I cannot see any leaks there is just a smell of petrol. I want to take the grinder to the car to remove the rust, and don't want a fireball while I'm doing this.
              From not a very good memory there is less then 1/4 of a tank left so want to understand the best way of removing the tank on the coupe. The boot area is already stripped down, can I remove it with the fuel inside the tank or am I best draining the tank first, if so what is the best way of doing that on this car.
              Thanks for any advice.
              • Bowie69
                • Nov 2013
                • 2675
                Just stick 12v to the pump and attach a hose to it, and dangle in a petrol can....
                Hand car was places are a good source of 25l cans.
                • johne
                  • Apr 2007
                  • 1405
                  The centre hole clearly has to remain on the horizontal centre line so either of the lower pictures is possible. Checking my car tonight, the mounting is fitted as in the bottom left photo. This was because I measured what I thought was best to get the bolt to line up within the slot in the subframe mount. As long as the bolt will pass through somewhere along the slot either of the bottom two orientations will suffice.
                  If you can, have a look at where along the slot the original OE mount bolt with its central hole sat before you took it apart. If the original was off-centre in the slot use the orientation of the replacement mount to bring it back towards the centre - even if it then overshoots the centre a little.
                  • struikie
                    • May 2019
                    • 314
                    Maybe this helps to see the direction Audi used?
                    JW
                    | project | 1993 Audi 80 VR6 turbo quattro |
                    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
                    • B5NUT
                      • Sep 2021
                      • 1071
                      The original OEM bush is centred, and you cannot buy the original bush, just the off centre version.
                        • Dec 2017
                        • 5992
                        A quick search and I found this. I'm sure there are others.
                        • B5NUT
                          • Sep 2021
                          • 1071
                          Thanks. I'll just put the old fuel into my wife's A3. I'll get some fresh fuel when I'm ready to start the car again.
                          • struikie
                            • May 2019
                            • 314
                            Ok, I missed that bit of info
                            JW
                            • B5NUT
                              • Sep 2021
                              • 1071
                              https://www.s2forum.com/forum/techni...fuel-tank-leak
                              Never smelt any fuel inside the car it was just when I was working underneath, so I'm hoping the tank is not cracked.
                              • B5NUT
                                • Sep 2021
                                • 1071
                                A single picture that captures the quality of the work done to this car in the past. Half arsed, half finished, half a job, that'll do.
                                Sums my car up nicely
