I might have some of those bulbs somewhere …
My S2 coupe bit of a rebuild and repair thread.
I'm fine guys don't worry, just had a bit of a stomach bug and been busy helping my folks.
Glad you got your leak sorted, I suspect it was that hose from the turbo causing the problem.
I can send you a bulb or two on Monday, I have about 90 of them.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
Well not much done on my S2 since I fixed the boost leak, and I've just had the pleasure of driving the car without any further issues. However a decision has been made about the car!
That is I'm not going to run it as my daily driver. When the bad weather comes and the roads get covered in salt, it will be put away under cover and my next project car will be used! Hair cut anyone? It's the 1.8 225BHP BAM engine model with the fake quattro haldex stuff
Nothing wrong with a BAM TT. Its basicly an Audi S3 mk1 Facelift with a different body. And when it functions properly, the Haldex is actually great.Comment
I know. It's why I wanted the BAM engine version rather than the lesser 180 version. Everything so far appears to work on the car including the Haldex.
However it does need a dam good service and a fair amount of work to bring it up to a good level.
Nice
Urs6 plus project goneComment
Looks like a good one, nice and straight, hope it was the right sort of money.
Be ready to do a cam cover gasket, they are notorious for leaking at the back, dribbling oil onto the EM which then evaporates making everything mucky in the engine bay, I've changed a lot of them. If you need any advice drop me a PM as I've probably done more work on this platform than any other, even got a few spares knocking about from an S3 I broke years ago.
Change the oil in the gearbox and rear diff as well as the filter as soon as you can if it hasn't been done, the Haldex will thank you for it, use the genuine stuff from TPS.
Not a fun job on the floor, must also be done on a level surface, there's plenty of good guides on YouTube regarding the job.
As Fish rightly says it's basically a MK1 S3, my folks had one when they first came out and I was really impressed by it back then.
Your only need to open a barbers shop if you've got a 180 model.
1994 MTM RS2.
2000 B5 TQS.Comment
Thanks Kit. I forgot about that gasket. I'm going to TPS this afternoon I will see if they have one in stock if not I will order one.
I'm planning very similar work as what I did to the S2 so all the fluids will be changed. Which reminds me I need pass fluid and brake fluid.
The is no history on the car so every job is being done if it needs it or not. Also going to drop the sump to clean it and flush and clean the pickup pipe.
I'll have lots of questions so will message you when they come up. Say that I do have one are there any special tools required for the cambelt change on this engine.Comment
Vac leaks are the big one of the BAM engine, all the hard plastic lines crack.
the cambelt only requires one tool to wind in the hydraulic tensioner, if you are replacing the hydraulic tensioner then you won't need it.
EGT sensors are fairly common too, you'll soon know as the boost will be capped..Comment
Start a new thread!
