My silver RS2 Project
    • Dec 2017
    • 5990
    Thanks.
    Looking for rear brake parts if anyone has anything knocking about. All the springs for the shoes, adjuster screws and bushes. Basically everything for the shoes is missing. I have new cables and calipers plus discs that should hopefully clean up.
    • jbrentd
      • Dec 2009
      • 247
      Will be watching...as usual. Congrats on what looks like a great project!
      2001 A4 Avant QMS - FXK04'd
      1991 Audi CQ - Project
      1996 A4 12v Quattro Manual - SOLD
      • rustybullethole
        • Aug 2013
        • 531
        Dave, i have put a link to my RS2 refurb below that i did on mine about 5 years ago, there might be something in there will help you along the way, things are hard to find and when you do find them theyre normally very expensive.
        Link: https://www.pistonheads.com/gassing/...=215&t=1823043
        But it was all worth it in the end
          • Dec 2017
          • 5990
          Thanks very much
            • Dec 2017
            • 5990
            Disassembled the rear shocks
            The springs will be blasted and coated. Getting quite a pile of stuff together to take to the sandblasting place.
            I was surprised that the rear small wishbone is pressed steel. I happen to have a couple of cast ones (as you do). They need the old bushes removing and blasting.
            • 4WDrifter
              • Nov 2012
              • 1251
              #21
              Bit of history
              1996 S2 ABY Coupe silver
              2003 S3 8L dolphin grey
              2014 RS4 B8 prism silver
                • Dec 2017
                • 5990
                A boot full of parts off for sandblasting.
                I seem to have a standard S2 EM.
                Anyone have a Wagner EM going spare? Standard turbo fit.
                Or maybe an RS2 one? Tradition have sold out.
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  How frustrating
                    My cave may hold what you need Dave
                      • Dec 2017
                      • 5990
                      Fantastic
                        • Dec 2017
                        • 5990
                        I've done very little since my last update. I have had a bug or virus or something rather nasty and been layed up for ages. Anyway, today I moved the engine into the garage from the barn where it was dropped two weeks ago. It's always handy having a tractor about the place.
                        And thanks to another forum member I have a nice set of Koni shocks to fit.
                        I had a look in the bores and can see some scores.
                        My leak down test kit is broken. I need to do a test before I remove the head.
                        My friend has one I can borrow.
                        The timing belt is the proper rs2 specific one and properly fitted with the top mark one tooth to the left. I have ordered a new belt and will swap the water pump pulley to a new ABY pump I happen to have.
                        I've been gathering new parts together slowly. Hopefully get going properly on this soon.
                          • Dec 2017
                          • 5990
                          So I managed to fix my leak down tester.
                          Cylinder 1,3 and 5 are good.
                          Cylinder 2 and 4 not so good.
                          And the air is escaping from the IM. So might be intake valve issue.
                          Anyway, head off next step.
                          I was hopeful I wouldn't have to rebuild the engine but it's looking that way.
                          Fortunately I have a full gasket set and head bolts here already (as you do).
                            • Dec 2017
                            • 5990
                            So this afternoon I got stuck into it.
                            I got this tool from Mike Dewar. What a lovely bloke he was. Think of him every time I use it.
                            • photongreen
                              • Jul 2016
                              • 22
                              awesome progress
                                • Dec 2017
                                • 5990
                                Collected my parts from the sand blaster. As usual, they have done a top job.
