My silver RS2 Project
    • Dec 2017
    • 5992
    A few more parts coming together.
    I wasn't able to finish the vac pipes as this is broken. Anyone tell me a part number or where to buy one?
    • sal_s2
      • 1288
      Motorcraft? Looks like a ford part
      • rxl
        • 1913
          • Dec 2017
          • 5992
          Thanks Rik.
          I did a temporary fix. I'm sure I have a spare (somewhere).
          I have two RS2 downpipes (as you do). I chose the best one. It's getting a clean.
            Harpic Power Plus 10X is brilliant on stainless exhausts. Just be sure to wear gloves and wash it off with plenty of water afterwards.
              • Dec 2017
              • 5992
              I will give that a go. Thanks for the tip.
              I made up a little heat shield for the engine mount. I've never seen one here but the etka shows one. Makes sense as the turbo gets very hot.
              Then the downpipe went on. This is difficult even with awkward access spanners.
              And my home made specials.
              Now I've hunted the forum but can't find the wiring diagram for the cooling fan resistor plate under the horns. I want to check I've got them in the right order if anyone can confirm.
              EDIT. Found it on S2 Central. Thanks Paul if you are reading.
              • John.
                • 2615
                Originally posted by Tractor Dave
                Nice repair that Dave
                  • Dec 2017
                  • 5992
                  Anyone have a drivers side one of these? No 15.
                    • Dec 2017
                    • 5992
                    Intercooler given a good clean and re fitted.
                    • rxl
                      • 1913
                      wow your moving so fast...
                        He's a machine! lol
                        • Nuvo
                          • Nov 2003
                          • 3825
                          #222
                          Part man, part tractor.
                            Hahaha
                              • Dec 2017
                              • 5992
                              The radiator, air guides and hoses got disassembled and cleaned.
                              The radiator is dated 2002 and seems in good shape.
                                • Dec 2017
                                • 5992
                                I'm not that far off going for a first start of the engine. I have no ac oil\gas in the system. Do i need to remove the ac belt to prevent damage or will it be safe with ac switched off and presumably the compressor clutch won't engage?
