Caddy side project
  • Jaswan
    • Apr 2011
    • 765
    #46
    Nooks and caddys
      • Dec 2017
      • 5984
      I think the door hinge in post 45 was welded on by a man with a white stick using his feet
        • Dec 2017
        • 5984
        Still beavering away. Into the engine bay atm.
        • struikie
          • May 2019
          • 314
          What did you do with that long drill bit ?
          JW
          | project | 1993 Audi 80 VR6 turbo quattro |
          | daily | 2018 BMW G31 530d | 345bhp 770Nm |
            • Dec 2017
            • 5984
            JW
            It has a wire brush welded on the end. Handy for getting into the nooks.
            • struikie
              • May 2019
              • 314
              ahhh I remember you posted that.
              JW
                • Dec 2017
                • 5984
                Got a few more parts cleaned and painted.
                And the gearbox got a good scrub.
                I'm almost ready to start the few bits of welding required
                  • Dec 2017
                  • 5984
                  First patch is in.
                  The other side is a bit worse
                    • Dec 2017
                    • 5984
                    Onto the drivers side. After cutting out the rot I found some more holes.
                    These two are through to the inside.
                    Anyway, cut it all out and patches made up and weld through primer applied.
                    A few complicated shapes this side but got there in the end using hammer and dolly. This steel is 1.6mm and not so easy to shape.
                    I think this section on both sides rusted as water and mud had become trapped inside at the bottom of the sections where they meet. I have left a drain gap at the bottom and will add plenty of good cavity wax inside.
                    My welding isn't pretty but it's strong.
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      That's looking great Dave, Caddy's are never totally rot free, you were really lucky to find such a solid example to start with.
                      It'll be well worth all the effort you're putting in now, will last for another 40+ years, probably be better than when new.
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
                        • Dec 2017
                        • 5984
                        But I found a good drivers door lower hinge that I can weld in. Happy face!
                          • Dec 2017
                          • 5984
                          I didn't have the confidence to do the hinge so my friend and neighbour (who is far better at welding than me) came over to give me a hand.
                          We drilled out the spot welds on both the car and the spare hinge.
                          Then carefully measured and cut out a section to weld in.
                          The old hinge was very rusty inside.
                          I cleaned up inside the bottom of the A pillar whilst I had access and treated some rust at the bottom. Then it got a good hoover and some weld through zinc primer before it was closed up.
                          The new hinge has tack welded in position and we fitted the door to check its position. We are good.
                          Then it was a matter of finishing off the welding.
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            Looking great Dave as always, you certainly are very thorough and that will show up in the end result.
                            Have you decided on a colour yet? There's a few 1980's VAG paint's that would suit it well. However my choice would probably be Oak Green, that really is a lovely colour and looks fantastic on car's with proper lines such as MK2's and Caddy's.
                            1994 MTM RS2.
                            2000 B5 TQS.
                              • Dec 2017
                              • 5984
                              Thanks Kit.
                              I've not made a final decision re colour. The car did come with a new 5l tin of the original green so I'm tempted to use that and save a few pounds
                              • struikie
                                • May 2019
                                • 314
                                Brave stuff!
                                JW
