Caddy side project
    • Dec 2017
    • 5995
    All the boost pipes and engine loom are sorted.
    2026-10-16_16-15-46_771.jpg The pesky slave is still leaking. I used a nice flat piece of metal sheet and some fine sandpaper to try and sand the mating surface flat but it didnt work. I think the thread has been cut into the slace at a slight angle so its never going to work.
    I did some research and found the kit uses Goodridge 600 hose. A quick call to Merlin Motorsport and they were able to supply a flared fitting for the slave that i can connect to the pipe. It should come on Tuesday. Retrofication have not been any help at all, failing to respond to any of my emails.
    • RedV6
      • Jun 2026
      • 77
      That is looking really neat. Maybe time to try another slave cylinder. What ever happened to clutch cables....! Oh yea, they pulled thought MK1 bulkheads, I seem to remember.
      • sal_s2
        • 1288
        Where are you going to mount the fuel filter? Doesnt the washer bottle fit behind the headlight?
          • Dec 2017
          • 5995
          Fuel filter is going right side of engine bay a bit further forward than it was originally. Washer bottle goes left side of engine bay infront of coolant bottle. Everything fits ( I hope).
            • Dec 2017
            • 5995
            Next job was to mount radiator and custom fan. There isnt space for the original fan and cowl and i had to move the radiator back and over slightly.
            2026-10-20_13-51-14_112.jpg 2026-10-20_15-04-59_216.jpg I'm waiting for some custom hoses to connect up the radiator.
            2026-10-20_15-05-28_262.jpg Next job is to sort the inside wiring and mount the ecu.
              • Dec 2017
              • 5995
              ECU mounted and wiring all sorted.
              2026-10-21_08-53-38_089.jpg Custom coolant hoses cut to size and assembled.
              2026-10-21_14-30-00_859.jpg 2026-10-21_15-56-24_579.jpg The fittings arrived from Merlin. Lets see if they leak.
                • Dec 2017
                • 5995
                I had some felt underlay left over from my Nothelle project. I cut some panels to size.
                2026-10-22_15-50-34_311.jpg and fitted them into the footwells
                2026-10-22_16-49-31_808.jpg I bought a new carpet from VW Heritage. It fits nicely and quality seems good.
                • Jaswan
                  • Apr 2011
                  • 772
                  #158
                  Looks lovely Dave!!
                  She is coming along nicely now.
                  Jase.
                    • Dec 2017
                    • 5995
                    The dash and cluster went in.
                    2026-10-25_14-31-28_468.jpg Next job was to make up the exhaust. I bought an off the shelf kit. It included middle and back box as well as bends, straight sections and joins. I was hoping it would bolt straight up but unfortunately it needed cutting to size and custom hangers fabricated.
                    • RedV6
                      • Jun 2026
                      • 77
                      Its nice to see the simplicity that is under the dash! Carpet looks great
