Project 'Can of worms'
  • s2driveruk
    • 12696
    lol Halfrauds.....the silver paint was originally to sort out the A6 bumper but its the wrong paint code.....stock colour is black
    1992 3b S2 Coupe
      It definetly worth replacing those brake hoses, brakes were transformed on my car when i did them, not surprising when you saw what the old pipes were like!
      • s2driveruk
        • 12696
        you're not wrong Greg, couldnt believe how mushy mine were!
        1992 3b S2 Coupe
        • Ski
          • 2591
          #49
          do them goodbridge hoses fit standard rear s2 brakes?
          ABY Coupe
          • s2driveruk
            • 12696
            yep thats what mine standard brake pipes have been replaced with....£29 a pair
            1992 3b S2 Coupe
            • Acidburn
              • 13459
              Gonna look into getting some goodridge hoses from Vagparts for front and rear of the car on mine, used them before and they've been brilliant. Just trying to decide about a rear brake upgrade or not....
              • s2driveruk
                • 12696
                so it arrived yesterday......you beauty
                1992 3b S2 Coupe
                • s2driveruk
                  • 12696
                  plate number....
                  1992 3b S2 Coupe
                  • s2driveruk
                    • 12696
                    wishbones anyone rears are about to go for a powder coat, along with the rear subframe once its off the car (this weekend hopefully)
                    1992 3b S2 Coupe
                    • s2driveruk
                      • 12696
                      new engine mount....one of the many replacement rubber mounts to hopefully rid the car of its thunking and banging about, especially when lifting off the throttle. These in combination with a new SQ snub, gearbox mounts, rear diff mounts and new prop centre mount, should feel like new
                      1992 3b S2 Coupe
                      • s2driveruk
                        • 12696
                        new rear wishbone balljoints, cheers Pete @ Quattro Corner looking in slightly better shape than the ones that came off the car
                        1992 3b S2 Coupe
                        • s2driveruk
                          • 12696
                          new oil temp sender....the one i changed about 3yrs ago is already weeping grrrr The smaller low pressure sender is also being replaced to stop the oil waterfall effect down the side of the block and sump, only to be blown the length of the car
                          1992 3b S2 Coupe
                          • s2driveruk
                            • 12696
                            new adhesive cork gaskets for either the driveshaft to diff flanges (should I manage to budge the current ones) or for the prop to diff can't remember
                            1992 3b S2 Coupe
                            • s2driveruk
                              • 12696
                              replacement water rail temp sensor for the fan/afterrun pump. Note the temperature rating...
                              1992 3b S2 Coupe
                              • Acidburn
                                • 13459
                                Looking good, doubt there is going to be much original on the car by the time you've finished.
