20V CQ Tidy Up
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    #586
    The pulley just exaggerates any wobble on the crank, making it easier to spot.
    SS
      Thanks for the tip mate, I'll bolt it up tomorrow and have a look
      • mcandmar
        • Apr 2004
        • 5118
        Originally posted by 4WheelDrifter
        Sgt Balancer refused to balance it, so I had use another crank.
        Was that Philip in BDB? He insisted i measured mine before shipping for that very reason
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • andy10v
          • 5996
          Originally posted by Error404
          Andy yes I have found not all shells are equal, so you have a bit of variation to play with.
          Trial and error with plastiguage? And then swap tight-loose?
          Sold ABY-stock
          • G60Rallye
            • Dec 2006
            • 1321
            Good to see you going into such detail on the build!
              Cheers Hamish
              Fit the caps and torque them, then measure the bearing tunnel with an inside micrometer or a telescoping gauge. Then measure the journal. The difference is going to be the bearing thickness plus the oil clearance. Then measure the thickness of all the shells and match them up as closely as you can to the cap/journal requirements. Then you can test fit the bearings in the tunnel and measure again the inside diameters to check. You can then use plastigage as a final stage during test fitting to check your work but it is really not designed as a measuring tool.
              • andy10v
                • 5996
                Great explanation, thanks!
                Sold ABY-stock
                • JariP
                  • 192
                  I measured the pistons and weighed them, matching them up with their respective rods. The pistons are within 0.012mm of each other so I will get the block bored to suit the largest piston - better to have a tad too much clearance than not enough. Worth noting that they averaged around 81.94 so just building it going by the box spec would have meant some of them were only running 0.055mm bore clearance - bad news! Always check!
                  Are you sure the 0.012mm difference is in the pistons themself or is it just the difference in skirt coatings? I think there's a note in some Wossner prochure that says the pistons are measured without the skirt coating. And measuring with coating gives you false readings.
                  Have you measured the actual cr those pistons give? Those look like the 8.0 cr pistons?
                  • AndyP
                    • 6049
                    I was about to ask the same, the dish look very deep for a stock piston?
                      That is a good point, there was no information in with the pistons, so I will check with Wossner. The only info I have was what was on the box sticker. They are the 8.0:1 pistons
                      • AndyP
                        • 6049
                        Big turbo?
                          not in the foreseeable future
                          • Pat D
                            • Dec 2011
                            • 748
                            • Country: Australia
                            #598
                            ABY S2 stroker (work in progress)
                            B5 1.8T quattro
                            B4 2.3 (decommissioned)
                              Jesus, that'll give me nightmares
                              • Pat D
                                • Dec 2011
                                • 748
                                #600
                                What type of coils will you be going with Alex?
                                B5 1.8T quattro
