3b s2 coupe resurrection
  • andy10v
    • 5996
    Error404 was kind enough to supply a big box of Quattro seat covers, so going to try my sewing skills!
    Sold ABY-stock
    • andy10v
      • 5996
      Should look ok once the cloth is tight.
      Sold ABY-stock
      • andy10v
        • 5996
        Having issues with pictures, hence the multiple posts.
        Sold ABY-stock
        • sidrick
          • Jan 2011
          • 1342
          Originally posted by andy10v
          Cleaned
          The misted window look. I can't remember the last time I could see through my windows in the morning from the outside
          • andy10v
            • 5996
            Yeah the goldfish bowl, I wouldnt have been surprised to find something alive in it. Sealing and re riveting the A pillar trims is on the to do list.
            Sold ABY-stock
              have you tinted your passenger side tail light? Looks nice
              Those Recaros will look the dogs with quattro script - did you ever see Jamo's old blue ones?
              • andy10v
                • 5996
                Nope, its stock, it does look very red in the picture? Reflected from the toolbox?
                All red US tails would look good!
                Yup, theses ones?
                Sold ABY-stock
                • Acidburn
                  • 13459
                  been a while since i've seen those seats of jamo's there was a thread about them from a rolling road day at mrc
                  • andy10v
                    • 5996
                    Rear bumper off, boot carpet out, trim off, rear inner quarter panel off.
                    Used a slide hammer to pull the arch out a bit more into shape, struggling to get to the back of a dent inside though. Also the inner and outer arch have started to seperate in a couple of sections. Do I need to pull them together and weld, or just fill with seam sealer?
                    Started removing the filler as well, some of it is well stuck down, some has come loose.
                    Anybody know a quick way of removing it?
                    Sold ABY-stock
                    • SteveH
                      • 4460
                      Get a grinder on it, that will shift it.
                      91 Modded 3B
                      14 A6 Avant Black Edition
                      • djh
                        • Jun 2011
                        • 1622
                        • Home: United States Current: United Kingdom
                        #356
                        or a dremel
                          A decent knotted wire brush on a grinder will make mincemeat of that filler.
                          The outer arch tub is just folded behind the arch lip, you should be able to fold the lip back carefully, there is also I believe a special tool available for this.
                          You could also weld a hoop to the dent and then use the slide hammer to pull it out.
                          I have all this to look forward to as i have a bit of surface rust emanating from an old repair on my arch, I'll be watching with interest
                          Rob aka GT500 is your man for advice on this stuff
                          • martinws
                            • Oct 2008
                            • 917
                            Looking good man. My 90 is in bits now as well. Is it gonna be ready for Creiff?
                            • andy10v
                              • 5996
                              Worked perfectly
                              Got a nasty dent at the door, right behind the seat belt mount
                              I cant find mine, and B&Q didnt have anything decent sized, off to Halfords tomorrow
                              Yup the outer is just folded (or was) over the inner, good idea on the hoop for pulling, thanks.
                              Once it is all in place would you use seam sealer on the joint? In the inside or outside?
                              I am also waiting to see what Newsh does, its not a particularly nice area to work on. Once I get this side sorted there is a bubble on the other arch that has developed from the rear bumper rubbing.
                              The 90 looking like the S2 bits will work without to much grief? I dont know when it will be done, I am not rushing this, I want to do it properly, once. But also want to use the car this year, so I think I will do stages.
                              Stage 1 (just now/next month or so)
                              Sort the rear quarter
                              Sort any damaged underseal
                              Sort the front seats
                              Make sure the shell is "sealed" and will not deteriorate
                              then fit
                              Turbo
                              injectors
                              fpr
                              ecu
                              exhaust
                              MOT, tax 6 months and drive this summer
                              Then maybe re bush one end etc next winter, sort the interior, engine bay etc etc
                              Hopefully by doing chunks it will get done, done well, I will not lose interest/spend to much at once etc.
                              Just going to throw the turbo etc on without opening the engine and drive it, if it pops then will take it from there.
                              Originally posted by djh
                              or a dremel
                              No Dremels shall be harmed in the restoration of this car.....
                              Sold ABY-stock
                              • andy10v
                                • 5996
                                Picked up some flap discs, they remove stuff quite quickly, good for cleaning metal for welding as well.
                                A bit of paint/rust removal
                                You can see the inner and outer here, with the fold
                                Also need to sort this, where the rear bumper bolts into the arch
                                Sold ABY-stock
