3b s2 coupe resurrection
  • andy10v
    • 5996
    New breather setup will be
    Crank breather to old head breather
    Modified pipe through the head will be the vent
    New cam vent to swirl pot
    Swirl pot drain to sump (below oil level)
    Swirl pot vent to catch tank
    The block will vent through the oil drain holes into the head, and also from the block breather into the stock head breather. The head will vent out the modified pipe in the cam cover. This is to combat oil surging out the block breather on hard right hand bends, out out the back of the head breather under hard acceleration. I am not sure if it is best to link the head and block via the stock breathers or not? I know Hank Iroz vented out just the head at 600bhp, relying on the oil drains for crank case ventilation and had no crank case pressure build up. Will oil slosh between the head and the crank case? Does it matter or would they be better blocked?
    Sold ABY-stock
    • martinws
      • Oct 2008
      • 917
      I'm going to do the very same thing with breather pipe. I have a stainless water separator that I'll put more baffles in with possibly a swirl pot or bmw vortex thing before it. Are you blocking the front or back of the new head breather or venting both sides?
      • martinws
        • Oct 2008
        • 917
        Ps. Do you think that with a bit of heat on the aluminium and water running through the stainless cam cover pipe you could pull it right out the back? Or is it all one piece?
        • andy10v
          • 5996
          I have blocked the front just now and will vent out the rear, could do some experimenting into coke bottles to see what is the best?
          Sold ABY-stock
          • andy10v
            • 5996
            The long pipe is alloy, I didnt check what the ends are. I think remember reading that you can just twist the front one and pull it out.
            Sold ABY-stock
            • andy10v
              • 5996
              Intake manifold off, wagner offered up for a test fit, hits the power steering pump as expected, shorter belt on order.
              Next problem
              Injectors in fuel rail and the front of the injector hits the intake manifold;
              Injectors in intake manifold
              Sold ABY-stock
                That's weird, I'm sure mine doesn't do that
                Is it a genuine Wagner IM?
                ABY fuel rail? Do the fuel rail bolt holes line up?
                • andy10v
                  • 5996
                  Its supposed to be genuine.
                  It was an ABY fuel rail I tried. The fuel rail is still too high in the pictures for the bolt holes to line up.
                  Sold ABY-stock
                    Following this with interest as I will be doing this some time in the near future
                    • andy10v
                      • 5996
                      Anyway strop over so went back out for another look.
                      ABY fuel rail does not work with a dizzy, so back to the 3b fuel rail.
                      3B fuel rail is tight but fits the wagner intake, popped on the throttle body and ISV.
                      Need to do something about a throttle cable, I am going to make a hard pipe for the ISV like a wagner one but from copper plumbing pipe
                      Intake will fit down between the crossmember and the radiator hose
                      Sold ABY-stock
                        Weird. I got the ABY rail to fit past the dizzy by bending the pipes up a bit, in actual fact the 3B pipe was a better fit to the stock fuel lines though..
                        I'll have a look at mine in a bit to check what the fit is like.
                        • andy10v
                          • 5996
                          Thanks, I might have a look at mix and match with some bending then, however would need to get the fuel rail fitting first.
                          Sold ABY-stock
                            I had a look and took some pics. The rail definitely pushes the injectors over at an angle, don't think it's as severe as yours but hard to tell.
                            One of the pics shows a sliver of daylight behind the mount showing that it doesn't bolt up flush.
                            There's a couple of the pipes bent to clear the dizzy too
                            • andy10v
                              • 5996
                              Thats great John, thank you for taking the time to do that. So it is tight but does fit, I will need to try wiggling mine a bit more, mine probably looks exaggerated as the rail is not down yet.
                              More lube and wiggling it is then!
                              That is great to see what you have done with the fuel lines, makes sense now.
                              Sold ABY-stock
                              • andy10v
                                • 5996
                                Started first time!
                                Major leak from the injector-intake manifold, time for new o rings
                                Sold ABY-stock
