Yep, brutal
I forgot to update the thread.... yep it's for the ECU to know what the operating temp of the engine is, along with a load of other sensors
Engine is running nicely now, opened the ECU and checked the chip.. clearly has 285 written on it!
Still working on the clever dash electronics and tidying up the wiring loom.
The immediate issue now is the road speed sensor that used to go via the dash and then to the ECU to let the ECU know the car was rolling, not just sitting still revving. As I have my own dash the wiring is somewhat different, so I'm trying to work out if the VSS wire can go straight to the ECU or did the Dash do anything with the signal, I'm thinking not, but I'm not quite sure how I can check it's working even when I connect it up!!
0-200km/h 9sec
