My 95 S2 Avant Project. LZ5T Coolness
    It's ok Dave we forgive you
      Nyuk.
      Anybody have measurements on the thickness of the ABY/ADU dual mass flywheel (DMFW) as compared the more svelt AAN DMFW?
        yeah the difference is the same as the thickness of the spacer
        It about 8-10mm - I have one at home I'll measure it later
          yeah the difference is the same as the thickness of the spacer. It about 8-10mm -
          Duh.
          • irishs2
            • Apr 2009
            • 2455
            Getting a little spendy on Audi tradition can have its benefits. Some nice new heat-shields.
            Even though I ordered a Sachs, I got an ATE. I didn't mind until I went to fit.
            The top of the slave cylinder interferes with the gear linkage spider.
            A little bit filing cured it though.
            Fitted my 3D printed nylon gear linkage bushes.
            After some heaving and hooing the engine is "in".
            Subframe and bambridge bushes support the gearbox end.
            Fill the gearbox with oil
            This is what I used.
            As my Dad used to say.."That much done!".
            It's still sitting on the old engine mounts. Will change over to the new bambridge ones eventually.
            Eric
            95 S2 Avant under rebuild.
              Woot! A real milestone - well done mate! You must be getting pretty excited now
              Interested to hear how you get on with those engine & gearbox mounts. I'll probably need to upgrade mine once I start going for more power, but I don't fancy anything too harsh. What are you doing for fuel lines? Is that the black tubes in the engine bay?
              • irishs2
                • Apr 2009
                • 2455
                Indeed. Its a little "cart before the horse" as there is a few jobs that would be easier with the engine out-of the way, but for my mind its the right way to go.
                They could be a bit harsh, so yea its possible I might regret it, but they are easy enough to change out.
                Yea they are the fuel lines. I kinda dont know what I am doing right now. Hopefully I can mate them to what I have and it will be good enough.
                I need to source some brass inserts to stop the line from crushing .. will look into it further down the road.
                Eric
                  Cool. I'm sure the plastic will work nicely.
                  As you say the mounts are dead easy to swap if you fancy a change
                  Now go do some more work and take pics
                  • Kieron20V
                    • Mar 2008
                    • 1505
                    #474
                    All this cleanliness makes me sad. Haha. Stunning work. Will all be worth it on the first hoon on the road!
                    1994 URS4 Avant RS2+
                    • Gimmi
                      • Aug 2014
                      • 72
                      • Country: Norway
                      #475
                      Great to read the new updates! All the hard work is done now, only the cosy things left
                      About por15 and your parts... Do you threat it with a form for precoating before using POR15? What did you do step by step?
                      • irishs2
                        • Apr 2009
                        • 2455
                        Thank you.
                        Yea, as with any paint its all in the prep.
                        1. Clean Part ( Blasting / Wirebrush etc)
                        2. POR-15® Metal Prep
                        This etches the metal and gives it a light zinc phosphate coating
                        3. Prepaint wipe the surface
                        4 Then begin POR-15 painting
                        At least 2 coats , 3 is better 1.5hrs between coats. When you brush it on, you will get micro air bubbles in the POR coat, thats one reason why you put on multiple coats to ensure full coverage.
                        Eric
                        • _ShurikeN
                          • Mar 2010
                          • 733
                          • Country: Russian Federation
                          #477
                          So would it be a good mod for an ABY / ADU where one didn't want the weight / inertia of dual mass flywheel, but equally didn't want a 'crudity' of 7A type flywheel ?
                          Just personal opinion:
                          No good. Both flywheels are heavy enough. ADY pressure plate shares partnumber with V8 plate and it should be stronger than AAN one.
                          Besides, among the two bad solutions (flywheel weight) personally I would chose one with double dampering (clutch disc + flywheel): long live the gearbox.
                          • cardcrash
                            • Oct 2009
                            • 763
                            • Home: England Current: Wales
                            #478
                            I just saw this in the flesh yesterday. Absolutely stunning workmanship. As I said to Eric, I don't know how he'll be able to bring himself to get it dirty by driving it.
                            RS2 - Project Mental Wheels
                            RS2 - LHD on the road again
                            RS2 - reduced to component parts
                            RS2 Saloon replica
                            A4 1.8T
                            BMW 320d Touring M Sport Business Edition auto
                              • 4754
                              Know what i mean?
                              Niiiiiice!
                              • irishs2
                                • Apr 2009
                                • 2455
                                Eric
