The '2 ton bugswatter' - back for a gentle stroke
  • Moose
    • Jul 2009
    • 4
    Damn, that intake is big!
      Sexy
      • Thuppu
        • 4115
        Nicely done JP, I will give you my address where to you can ship the manifold.
        • JP
          • 1858
          ^^^^ lol I'll politely ignore that......
          UrS6 Stroker + HTA3586 =
          • europeanme
            • Oct 2005
            • 3817
            me thinks there will be a few more requests....that, JP, is a work of art...
            • Audi_CQ
              • 940
              • Country: Norway
              #576
              Originally posted by JP
              Realising I was not going to get a long enough runner to tune to the second harmonic for my cam profile to optimise midrange I decided to go for the next harmonic in the sequence providing a tuned length that was short enough to fit under the bonnet.
              How long should the runners have been if space permitted? (I made a long runner intake, but didn't have a clue of the calculations you're using )
              • JP
                • 1858
                Depends on the volume of cylinderhead ports and diameter of tubing but without going back into my records it was around a 13" runner that I needed.
                • Nik0las
                  • 1345
                  • Country: Bulgaria
                  #578
                  you mad man!!! Are you a bank robber or something..?
                  marvelous work though!!!!
                  • URQguy
                    • Sep 2008
                    • 245
                    I went through the same runner length debate when I built my intake for my URQ(and others), but there just isn't room to put a 12" overall length from the seat to the plenum base with a radiator on the side. With an urS, it seems like you have the room. How come you bailed on getting the correct 2nd resonance? Surely you could have changed the TB location with your fab skills!
                    Love the manifold otherwise! Lots of cool ideas!
                    Hank
                    1981 URQuattro with the TIAL GT35r.
                    2007 Infinity g35
                    • URQguy
                      • Sep 2008
                      • 245
                      Pretty general overview of RPM vs runner length
                      2007 Infinity g35
                      • JP
                        • 1858
                        I did contemplate bending the runners and shifting everything about but came to the conclusion that the gains to be had where not worth the aggravation to make it versus the idea of using the plenum as a resonant chamber. The throttle body has been relocated as it is and to shift it much further from it's current location would have meant loosing a load of things like abs aircon etc defying what the car is meant for
                        Putting all that aside these will be the last pics until installation now after it has been clear anodised for low maintenance. Hopefully it won't loose too much of it's shine but going chrome is not to my taste as it looses some of the purposeful industrial feel to it.
                        Back of the manifold where the vacuum take off plate sits slightly proud of the intake acting like a settling chamber/junction block. Incl two threads for earthing the various stock earth wires.
                        Front of the manifold with a take of for the dump valve
                        Underside not as shiny but didn't think it was worth wasting the time to only risk breaking of some of the more fragile components, Featuring air temp sensor, idle valve, carbon canister, co2 spray bar and a bracket to brace/support the manifold to prevent cracking.
                        Top of the manifold incl the mounting plate for throttle linkage
                        Hopefully the next update will be the brakes and then the car finished for UD
                        • Rallye20vt
                          • Mar 2008
                          • 154
                          Thats VERRRRRRY nice
                          • AndyP
                            • 6049
                            When does the production run start?!
                              Originally posted by Newbie
                              Does that fit with a stock ABY radiator?
                              Looking even more sexy time there JP.
                                As usual JP, hats off to you for making all of us feel that our projects are inadequate and childish
