Codes as of today:
00523 - IAT Sensor-Temp High-Circuit Low-G42 same error code coule be Temp Low-Circuit High
01257 - Idle Air Control Valve
01247 - EV AP Canister Purge Regulator Valver-N80
01262 - Wastegate Bypass Ragulator Valve-N75
00513 - Engine Speed Sensor - G28
Not ideal...
IAT - Will test it this weekend but have ordered the plug which I hear often breaks down.
ICV - Had a replacement ICV since the codes were first pulled, so will need to look into this.
N80 - No idea.
N75 - Discovered this was unplugged when the codes were first read, the fact it still flags when plugged in is concerning. I have a new valve waiting to go in, and would like to replace the 8" section of loom that plugs into it. Any help onj a PN & price?
G28 - This is a new one. Again, no idea.
Not ideal...
N80 - No idea.
Stuck in a 10 amp fuse and cleared and re-read the fault codes.
