Project Zombie - 3B back from the dead
  • SteveH
    • 4460
    Originally posted by cab9fab
    The bay is looking great. I like the black intake/valve cover making the red coils pop.
    Today's fun and games has been finished off with refitting the clutch slave, what an absolute sh*te of a job. I've done it once before under the car and was prepared for some agro, but it was worse than I remember I eventually got it in place after soaking myself in hydraulic fluid and realised the bolt I had to hold it in place was the wrong one I think the thread in the gearbox is slightly stripped, so I'll remove it and tap it out larger when I have the car on ramps. The new Sachs clutch is quite a bit heavier than the old unit. Definitely one to build your leg muscles in traffic....
    91 Modded 3B
    14 A6 Avant Black Edition
      • 12431
      Did you fit the sachs race clutch this time around? Making pretty quick progress now aswell
      • SteveH
        • 4460
        Yes Greg, the Sachs clutch is in. It's a heavier pedal than my old unit but the engagement isn't too severe. It's not bedded in yet, but feels good
        Can't wait to give it some stick! I started her up yesterday with only the downpipe on I'm going to run her on the 3B RS2 setup until I can get it mapped with the ABY ECU, COPs and EV14's.
        This is the layout for the PAS and alternator. I've got a shorter V belt to avoid running close to the alternator adjuster. Hopefully the single belt will be able to take the strain of running both systems
        Test fitted the radiator and fan today, but have decided to get a bigger fan before connecting up the coolant lines. Into the paint shop in 10 days so I need to get the glass out next week. Plenty still to do for ADI...
        Phone pic, I'll get some better fitment shots tomorrow.
        91 Modded 3B
        • SteveH
          • 4460
          AND...big thanks to Rusty for the support getting a stuck spark plug out
          I have no idea why plug number 4 was almost seized in the head. I thought I was going to break it or strip the threads getting it out. There was no sign of any issues with the head or threads on the plug when we got it out
          91 Modded 3B
            it's easy when it's not your car and you're not the one holding the spanner Wasn't it cylinder 3?
            • SteveH
              • 4460
              The car is now stripped for painting. It's frightening what you find hidden under solid looking paint
              There was corrosion starting around the mounting holes for the rear lights and around the bolt hole in the rear quarter for the rear window seal. There was also corrosion starting under the trim that runs down both sides over the doors and windows. The worst thing with this type of corrosion is that you can't see it happening from the outside, so you could be oblivious to it until it's already got a good hold. Glass out is a must and a lot easier than I thought it would be. Three good coats of PPG Laser red 2K to go on this week and then a flat and polish.
              The challenge will be getting all the trim back on without scratching the paint.
              Thanks to the lads at Restomod who put in some hard work yesterday
              91 Modded 3B
              • re2500
                • May 2007
                • 2185
                Fair play, your bo77ocking on with it! This making an ADI appearance, or is that a tad adventurous?
                "Difficult is worth doing"
                • SteveH
                  • 4460
                  The car will be painted tomorrow and flat and polished by the end of the week. I'll then stick it on the ramps to fab the exhaust from downpipe to rear box. I'm aiming to have it back together within a week and off for it's MOT.
                  ADI shouldn't be a problem, however I've still got to sort out a running issue, do a cambelt change and think about doing the ECU and pin swap.
                  91 Modded 3B
                  • re2500
                    • May 2007
                    • 2185
                    In that case keep the pics coming
                    Im MOTing before the end of the week, 4 wheel align and then cambelt change. A quick wash and polish and ill be ready to tax at the beginning of Oct ready for ADI.
                    • SteveH
                      • 4460
                      Well the jaded laser red paint is a thing of the past...
                      Tailgate and trim should be finished by the end of the day.
                      91 Modded 3B
                      • s2driveruk
                        • 12696
                        wow, going to look fantastic Steve when she's done. How much was the full windows out job out of interest?
                        1992 3b S2 Coupe
                        • SteveH
                          • 4460
                          Yes, she should look sweet when finished. I guess you'd be looking at 1,400 to 1,500 all in, however I undertook most of the prep and supplied the 2K paint and activator, so it will be significantly less.
                          91 Modded 3B
                            Very much looking forward to seeing your handiwork
                            • TimE-J
                              • Jul 2009
                              • 1292
                              progress is great! Should look great at ADI!
                              96 S2 aby Coupe. Rebuild Project
                              96 mk3 golf tdi daily.
                              • SteveH
                                • 4460
                                The car is now back from painting and the process of putting all the trim and interior is underway. One sill left to paint satin black and the new wheels can go back on. I didn't get the exhaust finished, so that's now the only thing preventing a booking for an MOT. A few weeks till ADI and still plenty to do....
                                The paint isn't mottled, it's poor images from my iPhone
                                91 Modded 3B
