My Audi S2 coupè Version 2 - full restore - Red rocket from Norway
  • kinaputt
    • Jan 2012
    • 285
    • Country: Norway
    #91
    • kinaputt
      • Jan 2012
      • 285
      • Country: Norway
      #92
      • rxl
        • 1913
        wow it takes time to get the sealing material of the s2... you got skills and patience
        • kinaputt
          • Jan 2012
          • 285
          • Country: Norway
          #94
          Around 50 hours under the car and maybe 30-40 in the inside, taking out the asphalt mats.
          • kinaputt
            • Jan 2012
            • 285
            • Country: Norway
            #95
            I've done some more work. 550 hours in to the project now...
            Cut away this rusted crap.
            Started making the new piece.
            • kinaputt
              • Jan 2012
              • 285
              • Country: Norway
              #96
              I saw a video on Youtube by a fabricator, he hade a copper plate under the holes he welded. So i had to try it.
              It worked. Its really easy to weld holes with this method.
              I have welded some new studs for fuel line brackets.
              Welded from the inside.
              • kinaputt
                • Jan 2012
                • 285
                • Country: Norway
                #97
                I started laying some 2K-Epoxy underneath!
                This is the primer that i used.
                I also bought 7 cans of elastic underseal! Like the OEM rubberseal.
                • diesel des
                  • 3896
                  #98
                  Good work. I know just how hard removing that is. I spent 3 weekends doing it on my urq.
                  • kinaputt
                    • Jan 2012
                    • 285
                    • Country: Norway
                    #99
                    Update!
                    Im done with spraying Epoxy and seam sealing.
                    I had to grind some powder coat where the bushings in going to get them in place.
                    • kinaputt
                      • Jan 2012
                      • 285
                      • Country: Norway
                      #100
                      The car is now at the paint shop!
                      The car is going to be painted in the engine bay, inside and underneath.
                      I started cleaning som parts.
                      Next up is blasting the gearbox and painting it.
                        #101
                        Loads of work there - loving the chassis rotisserie - really want one of those !
                        • Filip_FIN
                          • Feb 2016
                          • 332
                          Such a nice finish on youre work very nice
                          ! What color is it gonna be?
                          Where did you find those headlights they look new?? I need some headlights to
                          Project Audi s2 coupé 1996
                          http://http://www.s2forum.com/forum/showthread.php?t=80796]
                          • diesel des
                            • 3896
                            #103
                            High quality work here.
                            • kinaputt
                              • Jan 2012
                              • 285
                              • Country: Norway
                              #104
                              I don't regret buying that!
                              Thank you. I think it will be painted in LY3D/Tornadorot.
                              I bought the headlights new from this place: http://www.niko24.de/Audi-80---B4---...HELLA_134.aspx
                              But i bought it from them via Ebay. They are around 3 years old now.
                              Thank you.
                              • Filip_FIN
                                • Feb 2016
                                • 332
                                Thank you.
                                Thanks for that ! I guess the headlights are for right hand trafic like norway and finland too ?and they are not even that expensive! Tornadorot sounds nice
