From Audi 100 to urS4 in a week
    • hunker7
      • Mar 2014
      • 3487
      #362
      Originally posted by Error404
      That's it. Trying to contact Audi, see what they want for such a thing, and need the bolt also.
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
        #363
        TPS is the parts company used by VW, Audi & others - you can buy without an account though. Their should be a local one near you - at or close to the dealer usually.
        Take your time and inspect all carefully... you confused me when you said the cam was aligned and the crank was not - lol - they are out of alignment... just hope you haven't bashed valves etc.
        Check that crank pulley super well and replace it if you have any doubts... I would replace the relay roller/pulley on the belt tensioner bracket as well for good measure along with the bottom bolt.
        PS - http://www.s2forum.com/forum/attachm...0&d=1276876987 - that shows the alignment of the three crucial sensors.
        G4 - crank position pulse in blue
        G28 - flywheel teeth in yellow (engine rpm)
        G40 - camshaft position sensor in green - it is active low for 16 flywheel teeth every TWO crankshaft rotations
        Note how G4 arrives in the middle of G40 pulse - when you see this you know that things are aligned properly.
        • hunker7
          • Mar 2014
          • 3487
          #364
          Check that crank pulley super well and replace it if you have any doubts... I would replace the belt tensioner as well for good measure along with the bottom bolt.
          Timing belt kit was changed some 10k miles back, so I won't be changing that.
          I didn't hear any BANGS so hope all 20 valves are fine
          Do I have to be a company of some sort to buy from them? Or I can just call them up and see if they have them?
          '93 Audi UrS4 Avant
            #365
            TPS will sell to joe bloggs like me and you no problem - you can usually get 10% discount or more off list by paying cash so don't be afraid to ask.
            • hunker7
              • Mar 2014
              • 3487
              #366
              Just called them up...and they don't have either bolt or the sprocket.
              '93 Audi UrS4 Avant
                #367
                Tried Pete at 'quattro corner' ?
                  #368
                  If all else fails - TPS can generally order anything in... can take a few days if its coming from Germany though, but usually next day if its sitting at Satan's lay-by (aka Milton Keynes).
                  • hunker7
                    • Mar 2014
                    • 3487
                    #369
                    Just called up Audi, and they quoted me £34 for the pulley, and £23 for the bolt. Cheap as chips, but they said closes Audi that could have them is 2.5 hour drive from me
                    TPS said they don't carry either of the parts.
                    '93 Audi UrS4 Avant
                      #370
                      TPS only stock what is common, but they absolutely can order anything. Anyway - you are in luck with the parts at a dealership so close by - get in !
                      • hunker7
                        • Mar 2014
                        • 3487
                        #371
                        Quattro corner can do bolt for £19 and £40-something for the pulley..neat.
                        '93 Audi UrS4 Avant
                          How do you know the timing belt kit was changed 10k ago? Was it the same person that skimped on the water pump, ****ed up timing it and tensioning it?
                          I would question the entire job, and do it again properly with good quality parts, if I was you
                          • hunker7
                            • Mar 2014
                            • 3487
                            #373
                            I have a receipt from a garage it was done in. I am sure water pump wasn't changed because then whole front has to come off. And you can see that the belt is new as well as tensioner. But i will check it once i take it off.
                            '93 Audi UrS4 Avant
                              #374
                              I assume you got a crank locking tool on the way ?
                              Please god don't try and do this by thinking you can lock it up with the gearbox !!!
                              • hunker7
                                • Mar 2014
                                • 3487
                                #375
                                I don't, need to buy one, opened a thread looking for someone who could lend me one. No replies
                                '93 Audi UrS4 Avant
