From Audi 100 to urS4 in a week
    #391
    Originally posted by hunker7
    Brilliant, thanks a lot. I better start measuring that thing up. I am not spending £70 on a tool if I can make one
    That is probably the easiest method to replicate if you have access to suitably heavy metal and the wherewithal to make something yourself !
    • hunker7
      • Mar 2014
      • 3487
      #392
      I am sure i can find something to make it out of. OK, I'll get to measuring
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #393
        Where does the tool bolt on to a block?
        '93 Audi UrS4 Avant
          #394
          This pic shows it pretty well with the 3256 tool... http://www.sjmautotechnik.com/troubl...tcranktool.jpg
          Actually - this page is very useful to read thru entirely for the AAN - its from well respected Audi tech in USA - http://www.sjmautotechnik.com/troubl...g/S4timing.htm
          • hunker7
            • Mar 2014
            • 3487
            #395
            Brilliant, thanks mate.
            '93 Audi UrS4 Avant
              #396
              Note the difference with the 2084 tool which counter holds on the snub mount itself... but the jaws in the round end of the 2084 tool need extended to work on the AAN/ABY/ADU pulley.
              • hunker7
                • Mar 2014
                • 3487
                #397
                I have to bolt it in where mount for DV hose goes.
                '93 Audi UrS4 Avant
                  #398
                  I've only ever used the modified 2084, but it looks to me like the 3256 bolts into a hole that is used by the snub mount.
                  The DV isn't mounted to anything - it is essentially held in place by the MAF pipe... unless there is some other bracket down there on the AAN that I've never seen before.
                    Could you not just make the holding tool really long and rest it on the floor or an axle stand. You also need a really big torque wrench to tighten the bolt. The pulley has probably slipped because the "garage" did the job with a rattle gun (air gun).
                    • david1980
                      • May 2014
                      • 1025
                      Do this with it resting on the floor, I did this with an s2 recently and works a treat.
                      What garage messed this up in the first place?
                      • hunker7
                        • Mar 2014
                        • 3487
                        #401
                        I'll have the tool finished tomorrow and also will have my bolt and sprocket done.
                        '93 Audi UrS4 Avant
                        • hunker7
                          • Mar 2014
                          • 3487
                          #402
                          Got the tool welded up, cooling down now will see if works tomorrow. Wish me luck.
                          '93 Audi UrS4 Avant
                            #403
                            Pics - we need pics :-)
                            • hunker7
                              • Mar 2014
                              • 3487
                              #404
                              I will test it before posting pictures
                              '93 Audi UrS4 Avant
                              • bikerjim
                                • Feb 2008
                                • 1028
                                Good luck pal. I know only too well the rush of having to get car stuff done around uni. Stick with it.
