Here's some pics of the HVAC & Matrix Removal - hover over the pics to get the IMG number referenced below
4449 - location of electrical connections (red block wrapped in foam and 2-pin brown plug) - no need to unplug anything else
4462 - pollen filter under the rain tray - nice biological warfare going on there
4464 - filter removed to expose the temp sensor and 2 x mounting screws
4467 - temp sensor removed from filter housing as the sensor needs to come away with the HVAC casing
4468 - one screw is actually a spacer piece for the filter housing so make sure and remove that
4470 - the drain hose from bottom of evaporator inside the cabin
4471 - the vacuum hose connection in the engine bay (for recirc valve operation)
4472 - vacuum hose where it enters cabin via restrictor grommet
4473 - vacuum hose removed from 1-way valve in engine bay
4474 - the upper matrix mounting bolt on the bulkhead
4478 - the lower bolt is lurking behind the brake pipes
4476 - removed the grommet for the water matrix hoses to release tension
4479 - get the ****** out
4481 - look at all the space up there
