My sleeper
  • hammer
    • May 2008
    • 242
    • Country: Austria
    #226
    Originally posted by diesel des
    Ok so at full power and 2 bar boost you should be seeing almost 7 bar of fuel pressure on the fuel rail. That's the important part and will show up any issues with pumps and filters etc.
    At 2bar i have ~6.8bar fuel pressure. So the fuel System is ok
    • hammer
      • May 2008
      • 242
      • Country: Austria
      #227
      Also the smallest diameter in the fuel rail is 10mm.
      A friends car have on this dyno also 600hp and on a other 745hp!
      I think that the 80% duty is ok if its 750ph with only 2bar boost
      • Tille
        • Feb 2014
        • 41
        Originally posted by hammer
        By a normal car. Not with my cam Timing and injectors 8 cm more back then oem. Also the inner diameter is bigger, so its not enough flow with starting rmp
        Your points describe why it has rough idle and cranking for general. If the cold start is hard compered to warmstart, change the coldcrank/afterstart Acc.enrich. settings.
        Audi Coupe Typ89 10V Turbo - VEMS - Billet K26 - Deka 630 - E85 - 3" Exhaust
        • Ficksy Heart
          • Jan 2014
          • 58
          Hattest du die KGE nicht direkt an den Auspuff angeschlossen? Ich würde einen Abscheider dazwischen hängen.
          Audi UrS4 20VT Precision 6262, VEMS, CatCams, SOLD
          VW T4 TDI Multivan
          pleasure by pressure...
          If you are not breaking parts, you're not going fast enough...
          • hammer
            • May 2008
            • 242
            • Country: Austria
            #230
            Hab nach dem Motorschaden einen eingebaut.
              English please
              • hammer
                • May 2008
                • 242
                • Country: Austria
                #232
                Sorry.
                He asked me why i didn't install a Separator in my Breather. But i installed one after engine rebuild
                • Jaswan
                  • Apr 2011
                  • 767
                  #233
                  hi Hammer, do you have any more info on using the golf gear selector/shifter please?
                  Great car, i am looking forward to an update
                  Jason.
                  • Nick320
                    • Nov 2013
                    • 52
                    • Home: Bulgaria Current: Canada
                    #234
                    Very nice. I likey.
                    • hammer
                      • May 2008
                      • 242
                      • Country: Austria
                      #235
                      Jason.
                      No, i install it at christmas holiday. First i have to finish the engine maping. I bought 2200cc injectors and Hope to get them next week [emoji4]. At saturday i go to dyno again.
                      • hammer
                        • May 2008
                        • 242
                        • Country: Austria
                        #236
                        Her 2 pic to See how Hot my downpipe was on the dyno[emoji15]
                        The holder for Abs connector was over 5 cm away from downpipe
                        • happykriss
                          • Mar 2013
                          • 60
                          • Country: Norway
                          #237
                          Your sure get your hands on some fun toys! Love this build!
                          • hammer
                            • May 2008
                            • 242
                            • Country: Austria
                            #238
                            Yesterday i got my new injectors
                            Today i installed them and they work fine.
                            • blackS2
                              • Apr 2010
                              • 455
                              what is the size in cc? 980?? aka 040?
                              I got 980cc from Finjector:
                              [__]=oooo=[__]
                              • hammer
                                • May 2008
                                • 242
                                • Country: Austria
                                #240
                                2210cc@3bar
