Titanium Grey S4 Avant
that dash looks nice and RED!!
no messing around with the bulb contacts tabs, janis? bending, twisting etc?
could you tell me how to get the climate control out without damaging the surrounds?
1997 Audi S6 - The Purple Helmet!Comment
It's genuinely perfect.
Perfect fit Craig! Not even one had to be adjusted. Only thing I can say is test before fitting everything back, because some I put in the wrong way round
I removed stereo fascia and surround, then pulled it from top and it came off fairly easily.
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
excellent, thanks! those red LEDs give a much stronger glow than the OEM ones - i LIKE!!
'93 Audi UrS4 Avant
I've noticed sometimes when I start the car it doesn't pick up revs. It sort of sits between 200-400rpm and once I rev it slightly it sits at normal rpm? Any suggestions?'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
I have never had any success whatsoever in cleaning them out, Janis.
You're supposed to blast it out with carb cleaner then drop some silicone oil in there and that's it. Don't bother buying a second hand one - they are bound to be as knackered as the one you've already got. New ones are expensive so make sure you rule anything else out.
Any other suggestions from you lot out there?
Don't use carb cleaner, wash it out with GT85 or WD40.
Carb cleaner is way too aggressive.
Also check the throttle pot switch is actually closing, it needs to for the ISV to work.Comment
