Ok, just had an update from Will, spec creep just got a whole lot worse, received this in text form:
Update city - Drilled brake discs front and rear ordered, callipers at paint shop, brackets being machined, compound 08 performance friction pads ordered. KW v3 on order, subframe bushes on order, engine and gearbox mounts ordered, Apikol rear diff mounts ordered. Head at machine shop as is block and crank, Mahle rings and Motorsport bearing shells have arrived inc thrusts. Block to be painted satin black. Cat-cams ordered. Pistons being machined. Rear subframe/wishbones/control arms all being powder coated. Solid rear axle bushes to go in.
And now there’s talk of a Wavetrac rear diff??? Apparently will be “epic”
Should make ADI and have Dave Rowe on hand for MoTeC support… looking forward to that!!!
