Project Mental Wheels
  • A1QSHIP
    • Aug 2004
    • 975
    Originally posted by cardcrash
    They are €18.39 each, the nuts are €3.93. 8A0615335 & 8A0615336 are the codes for the ducts on Audi Tradition and N90651601 for the brass hex nut. They told me that N0122307 was the code for the spring washers but they didn't have them, but Kit managed to pick some up cheap from TPS
    Thanks for that. The price does not seem so dear.
    "Nulla tenaci invia est via"
    • cardcrash
      • Oct 2009
      • 763
      • Home: England Current: Wales
      #122
      There's freight, which was about €25 - that's to the UK.
      RS2 - Project Mental Wheels
      RS2 - LHD on the road again
      RS2 - reduced to component parts
      RS2 Saloon replica
      A4 1.8T
      BMW 320d Touring M Sport Business Edition auto
      • DNA-S2
        • Sep 2012
        • 369
        I rather keep mines as I have paid more
        Buy them from above...
        It's no brainer [emoji106]🏻
        Danny
        www.dnaautocare.co.uk
          • 4754
          Were you shocked that Audi Tradition had them at such a fair price?
          By the way the build is looking awesome!
          • cardcrash
            • Oct 2009
            • 763
            #125
            Thanks - all credit to Will though!
            When I told Will that I'd got hold of a pair, feeling pleased with myself, he just said: "I've got a set here you could've had, have you got the special nuts you need?"
            Didn't feel so proud then and had to email AT as to the availability of said nuts...
            But yeah, I was expecting them to be something ridiculous like €70!!
            RS2 Saloon replica
            A4 1.8T
            • sailaz
              • Oct 2009
              • 647
              • Country: United Nations
              #126
              .....I came out with more scribblings, this time reading ‘Borg Warner EFR6758.....
              but you ended up with EFR7163 if I understood correctly ?
              • cardcrash
                • Oct 2009
                • 763
                #127
                That is correct, here it is with the notepad used for the scribblings:
                RS2 Saloon replica
                A4 1.8T
                • cardcrash
                  • Oct 2009
                  • 763
                  #128
                  Crank going in:
                  Some rods & pistons:
                  RS2 Saloon replica
                  A4 1.8T
                    Stock Pistons?
                    • cardcrash
                      • Oct 2009
                      • 763
                      #130
                      These are the original rods:
                      They look skinny, like twigs in comparison.
                      The new ones are 'VRS H-beam' rods "...are strong as #%£!, and won't break." Apparently.
                      *edit: oh yeah, the piston 'heads' are stock, may require some skimming but yeah, original.
                      RS2 Saloon replica
                      A4 1.8T
                        I was going to suggest skimming them to drop the CR a bit
                        • cardcrash
                          • Oct 2009
                          • 763
                          #132
                          Updates coming thick n' fast now:
                          I had no idea what 'ARP Ultra-Torque' was so I looked it up:
                          RS2 Saloon replica
                          A4 1.8T
                          • cardcrash
                            • Oct 2009
                            • 763
                            #133
                            Illustrating the before and after machining:
                            An unmachined piston in front of a bank of prepared pistons before entering the block:
                            1, 2, 3, 4, 5...
                            Twist, turn, screw...
                            And in they are:
                            RS2 Saloon replica
                            A4 1.8T
                            • SE_30
                              • Apr 2010
                              • 1114
                              • Home: England Current: Israel
                              #134
                              As Bernard Matthews once said... Bootiful..
                              Coming along nicely now Charlie..
                              Stuart
                              B2 90 quattro with boost
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                That's good to see, hopefully it should all come together quite quickly now.
                                1990 B3 2.0 80 quattro.
                                1992 C4 2.8 Avant quattro
                                1994 MTM RS2.
                                1998 B5 TDI quattro Sport.
                                2000 B5 TQS.
