Project Mental Wheels
  • cardcrash
    • Oct 2009
    • 763
    • Home: England Current: Wales
    #166
    Originally posted by will20v
    thats an oil temp sensor so we can have a safegaurd in the MoTeC ecu for high oil temps it will reduce power so Charlie doesnt nail the engine lol
    I will be driving the car always as if I was taking my driving test.
    RS2 - Project Mental Wheels
    RS2 - LHD on the road again
    RS2 - reduced to component parts
    RS2 Saloon replica
    A4 1.8T
    BMW 320d Touring M Sport Business Edition auto
    • sailaz
      • Oct 2009
      • 647
      • Country: United Nations
      #167
      the diff mounts are our own product.
      oh, somehow I have missed other photos where is VRS logo on the mounts (carriers) ...
      Do you make them for selling ?
        • 4754
        Believe that and you'll believe anything!
        • cardcrash
          • Oct 2009
          • 763
          #169
          Here's the VRS logos, slightly more visible:
          And then just coloured in:
          RS2 Saloon replica
          A4 1.8T
          • sailaz
            • Oct 2009
            • 647
            #170
            yes, that's what I was saying that I have missed where is the logo.... miscommunication ....
            anyhow does VRS makes them for sale ? was about to order from 034 ....
            • cardcrash
              • Oct 2009
              • 763
              #171
              I've told Will, he will message you.
              RS2 Saloon replica
              A4 1.8T
              • K Simmonds
                • Dec 2007
                • 7627
                Hmm, can't see that lasting long given the thrashing you've given your stock example...
                Nice to see it coming together, it'll be well worth the wait
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • cardcrash
                  • Oct 2009
                  • 763
                  #173
                  A little more progress as the engine hangs, ready for installation:
                  RS2 Saloon replica
                  A4 1.8T
                  • Dima ABY
                    • Sep 2013
                    • 183
                    • Home: Ukraine Current: Spain
                    #174
                    Nice !!!
                    Looks very promissing engine!
                    • cardcrash
                      • Oct 2009
                      • 763
                      #175
                      Engine's been mounted about half an inch back, every little helps:
                      Some senders and general shininess:
                      Heat shielding:
                      More mount shininess:
                      Super fancy coolant header tank, plastic fantastic:
                      RS2 Saloon replica
                      A4 1.8T
                      • Geoff
                        • Oct 2015
                        • 8
                        • Home: England Current: Australia
                        #176
                        Excuse my ignorance (I'm very much not a mechanic)...how do you mount the engine further back? Shallower flywheel?
                        • cardcrash
                          • Oct 2009
                          • 763
                          #177
                          Gearbox spacer is removed then yes, custom billet flywheel. Engine is then forced back as far back as it will go on the mounts. Just had William re-explain it to me, I'm no mechanic either!
                          RS2 Saloon replica
                          A4 1.8T
                          • Geoff
                            • Oct 2015
                            • 8
                            #178
                            That makes sense. Thanks for the explanation
                              Standard mounts have ~15mm of adjustment - just push the engine & box back as far as it will go. Removing the /DM flywheel gearbox spacer gives you more room to move. Custom flywheel is not necessary - 7A or 3B SM units are easy to get hold and cheap.
                              FWIW you could go back another ~20mm with custom / modified engine and gearbox mounts before you run into major clearance issues.
                              • cardcrash
                                • Oct 2009
                                • 763
                                #180
                                Yes I didn't mean to imply custom flywheel was necessary just what was installed on my car. As for modifying the mounts it's an unnecessary expense. You'd think with the money I've spent so far, what's the difference but you've got to draw the line somewhere. If I chased every little extra detail I'd end up spending over £100k Half an inch is cool with me.
                                RS2 Saloon replica
                                A4 1.8T
