Hydraulic to Vaccum servo conversion
This is a sticky topic.
  • Bowie69
    • Nov 2013
    • 2681
    Cabriolet has a vacuum system, the hydraulic system was only fitted to the 5-pots.
      Here is another option
      • etsola
        • Feb 2015
        • 285
        Originally posted by running_cold924
        Would one for a urs4/6 work? I just did this conversion to my car, used one from an a6.
        Do you have a part # by any chance
        • running_cold924
          • Jun 2018
          • 28
          4A0612105 is what I used. I do have a fresh rebuilt one too.
          • etsola
            • Feb 2015
            • 285
            This part # doesn't bring back any results ...
            I found 4A0 612 107 A
            A6 from '95 to '98 ?
            Thanks
            • running_cold924
              • Jun 2018
              • 28
              This was directly off a 96 a6 with the 2.8. I think the last letter is P. Was very worn when I purchased it. Here is another
              https://www.ebay.co.uk/itm/Brake-boo...cAAOSwT4ZbFwjJ
                Just to be clear, LHD and RHD have different considerations for the vacuum conversion.
                The RHD cars can only use the smaller diameter servo/booster due to proximity to the turret, so be sure you are buying the right parts.
                • etsola
                  • Feb 2015
                  • 285
                  Thanks buddy
                  • running_cold924
                    • Jun 2018
                    • 28
                    No problem. Like I said I have an extra, just rebuilt. If you are in Canada I can ship it to you. I had 2 used ones leak on me (sucking vacuum around the center bore seal) and finally found a good reman version. If interested just send me a PM.
                    • marius555
                      • Apr 2012
                      • 126
                      • Country: Romania
                      #175
                      Dear friends.
                      After changing about 7 ( seven ) a8 d2 boosters i managed to solve the issue using the adapter received from Alex.
                      Very important : DO NOT USE OLD PUMPS / BOOSTERS ! If it has been stored outside or on a shelf somewhere its most likely going to fail ... if you buy a sh one make sure that is on the car and the pump has the reservoir attached and brake fluid into it otherwise you will have to change it again and again ....
                      I used A4 B7 booster and its pump. The result its amazing and i am very happy with it .
                      Shopping list :
                      - Alex ( Error404 ) kit for urS
                      - 8E0 612 105 N booster with pump
                      - brake lines from a4 B7 ( the angle of the brake pump is different than stock and these ones from b7 really look nice ).
                      - as much beer as possible :-)
                      Have a nice day
                      Marius
                      • Wrath
                        • Jan 2011
                        • 779
                        1995 Audi S6 - AAN (~350hp)
                        2008 BMW 530xd (235hp)
