Hydraulic to Vaccum servo conversion
This is a sticky topic.
I will take a pic or two of the A8 and A4 boosters. A8 should fit with no problem in LHD.
Just very big for RHD where proximity to engine inlet, throttle body could be a problem.
Also, will clarify bolt / attachment layout. Off hand, A4 is bigger diameter but shorter in over all length than the A8, if my memory serves me correctly.Comment
Here are the pics of the A8 and A4 B6 boosters.
A4 fits. A8 does not fit thru attachment plate and therefore pedal set, as the nose piece dia is too big.
Also note length from firewall to end of master cyl, is shorter on the A4 unit.Comment
IIRC I heard some where is that the difference between 105A and 107A is the size of it. I have 107A (an inch bigger) one and fits perfectly, but dont know how size affects.Comment
http://www.ebay.co.uk/itm/2008318148...84.m1439.l2649
I just bought this one from 2000 a4, I am trying to fit it to lhd ur quattro, will see when it arrives.
Thankssigpic_________
RobComment
Yes I think you are right on the LHD, but I don't think there is room for a bigger unit on the RHD as the servo is closer to the suspension turret, there is only one size vacuum servo in RHD.
Lets not complicate matters by comparing LHD and RHD parts though
Imola B6 S4 AvantComment
Just out of interest, has anyone had issues with the one way check valve going bad and losing boost as a result?
I have an AAN in my Vanagon Syncro 16 which makes only 11-12psi (chipped ECU) and my brakes are now very hard to work!!
The van has been parked up for a while as we've just moved house but my daily driver Van (Tristar Syncro with 7A) developed a fuel injector body leak so I'm driving the 16 today.
MGComment
A couple of things you can check - pull the vacuum line off the servo and hold your thumb over it, start engine. You should feel a good vacuum on it. Switch off engine. It should hold vacuum for a while - if not the check valve leaks. If it does I am sure boost will not be doing the servo any favours!
Also check the seal between the master cylinder and the servo. A brake fluid leak can damage the seals and get inside and also damage the diaphragm.
I have two check valves inline on mine as insurance against boosting the servo. One is the OE check valve the second one is ff a TT - I figured that would be designed to take boost.
I had a black one way valve from VAG cars but not sure if it was taken from B5.working flawlessly just make sure you
plumbed her on the correct direction.I remember the check valve has a 2 small nipples available for another system that required the vacuum soruce as well.i just plugged them off.one of a few I5 from Asia.Comment
In my RS2 I have fitted the double one from A8 D2 (4.2) without any problems ....Comment
