Nice work Horsty
I tried this on RHD with a D3 servo (same size/fitting) but it doesn't fit, there is not enough room for the master cylinder.
I am working on a adapter plate to mount the servo directly to the bulkhead. The bulkhead and pedal box need to be modified to allow the larger 60mm bellow to fit through. Even then I don't think it will work with the standard ABY/3B/RS2 intake pipe, reverse intake will be needed I think. I am going to use the 26.9mm master cylinder too
