Bowie69: Thanks, i have already ordere 1 piece from A80 TDI
Hydraulic to Vaccum servo conversion
This is a sticky topic.
I have a bolt-on conversion kit for the dual stage servo:
https://www.s2forum.com/forum/member...conversion-kit
Attached FilesPanthero Coupé quattro 20vt
Imola B6 S4 AvantComment
Over here this seems to give me a master cylinder ... Ans it is not in 7zap either.
Any other suggestions ?
Would this fit ?
191612107A
357612107A
Brake Pressure Booster for 89-95 Corrado, 85-92 Golf, 85-92 Jetta, 90-97 Passat. ?
If I use the 7a master cylinder ? or will the one with the model mentioned above work (if I replaced the 7a with it) ?
ThanksComment
I thought the Cabriolet was the exact same thing as the 90 ... so with hydraulic brake system ... No ?
So ... What is the important part ?
The diameter of the master cylinder needs to match the one of the Servo (Brake Booster) ?
i.e. 7a Coupe Quattro has a 25.4mm master cylinder ... can I take any brake booster that has that diameter ? Can other (for example smaller) brake booster be fitted ?
Because there seem to be the VW T4 that has a 25.4mm master cylinder as ours ... will this work ?
Thanks
