996 rear calipers and Brembo handbrake for the coupe
This is a sticky topic.
  • Guslotti
    • Mar 2011
    • 182
    • Home: Italy Current: Brazil
    #61
    Originally posted by John B
    That depends on what wheel you are running. I have an Oettinger 17" wheel and there is plenty of space at the the rear. Here is a picture: -
    [ATTACH]40896[/ATTACH]
    HTH
    I'm thinking to use with original Avus, S8 Avus or Bolero. Do you have some idea if I can have some problem?
    • Henkjan
      • 1705
      avus should certainly be OK, the 16" even fit over 312mm discs (tested on the front).
      • Guslotti
        • Mar 2011
        • 182
        #63
        my question is not about diameter distance. Is the distance to the hub.
        • Henkjan
          • 1705
          OK. can't help you yet, my rear brakes are still on the shelf
          • Henkjan
            • 1705
            ... The regulator is different which gives the balance between the front and rear brakes and this is to be expected as the S2 only has a single piston floating caliper versus the 4 piston fixed caliper of the RS2.
            would you recommend using the RS2 regulator when doing the rear brake upgrade?
            btw: acc to your PDF, the "late" ABY and the ADU both have the same regulator 8A0 612 033.
            • John B
              • Apr 2008
              • 926
              I can only go by my experience which is all road-based. I don't do trackdays with this car . Anyway I have done hard braking on the road in dry conditions and there was no issue with the balance. What about slippy conditions? Well we in the UK had some severe snow conditions in the Spring this year. On one day, I was in the southern Lake District and all routes through the county were blocked to get home in the West. I was forced to do do an anti-clockwise tour of the Lakes in full-on winter conditions. The car performed very predictably under braking in snow and ice. In fact the only issue i had was cooling bizarrely because the whole of the radiator grille got blocked with snow and i had to stop to scrape it off. Our 20V turbo motors certainly keep us warm on very cold days
              2001 996 C4 - Being renovated
              • Sonic
                • Jul 2006
                • 5514
                #67
                Just reading through this as im looking at the options and i notice you've mentioned brembo handbrake calipers but the parts list has AP Racing handbrake calipers - are these correct?
                S2Forum.com Administrator
                • twoqu
                  • Sep 2003
                  • 3103
                  #68
                  Think Brembo bought out AP or something!
                  Earlier in the year I was quoted £338+carraige+VAT by GD Cars for a pair of those handbrake calipers. So they are £420 now!
                  • Sonic
                    • Jul 2006
                    • 5514
                    #69
                    Inflation eh? Typical
                    Thanks for clearing that up.
                    • John B
                      • Apr 2008
                      • 926
                      AP Racing is a brand name owned by Brembo
                      The caliper has Brembo part numbers and is used on the Gallardo / R8 etc. but comes in an AP Racing box There may be other places that stock them but GD Cars were reasonable when i bought them and great service
                      • Taje
                        • Aug 2009
                        • 8
                        • Country: France
                        #71
                        Hello,
                        Is this upgrade for avant/berline too or coupe only ?
                        • John B
                          • Apr 2008
                          • 926
                          .....afraid it is only for the coupe as per the title of the thread
                          • Taje
                            • Aug 2009
                            • 8
                            • Country: France
                            #73
                            What a noob I am ��
                            Then, the only way for me is to upgrade with S4 B7 brake.
                            • hardtop
                              • Feb 2015
                              • 1
                              thanks JB for your time and effort into producing this thread
                              • John B
                                • Apr 2008
                                • 926
                                It was a pleasure. I took the beast out for a thrash yesterday and apart from the driveline noise that is driving me nuts , one of the stand out features of the ride was how good the anchors are with this setup. Go on.....you know you want to
