Actually you don't need much rewiring on typ85 fusebox. If you have earlier one without necessary fuel pump pin - you just need to change it to audi100 one (everything else matches). If it's ok, then put KE-Jetronic fuel pump instead of K-Jetronic (you need one with fuse) and wire plug from ECU to it. Relay just needs to get ground signal from ECU. Also it's hard to get proper +12v with ignition for ECU (constant supply is trivial - just single wire from fusebox or battery). I have modified one of the plugs, which I think originally goes to big K-Jetronic idle stabilisation relay (black fusebox plug?), and tap some thick wire there by using wire tapper, which is available in electronic shop (used for trailer lights).
For tachometer signal - there's connector hidden under center vents (zebra wire, don't remember color). I have wired connector to there. However I have digidash, with arrows dash, you need to work something with tachometer (never did that, however average electronic guy can figure out what is wrong).
For temperature gauge - I've just wired wire back from motronic (mfts) to orginal sensor plug, which is now under fan/firewall cover.
That's basically it. Proper power supply, temperature gauge, tachometer, diagnostic plug, and potentially economizer signal to the dash. Not so much I would say...
Sau
P.S. I need to collect all this I write every time to some normalized form
. Now I think is about 10th time I'm writing everything from a scratch.
Sau
