Hello at all.
I have a problem with my AAN in type85.
The fuel pump relay don't close.
I have this connections:
- T to pin 3 of motronic
- 87a to injectors N75 etc...
- 87 to fuel pump
- 86 +12v after ignitiont
- 30 +12v permanent
I tried to get 12v to hold it closed but it doesn't want to close.
i did this:
- 87 to fuel pump
- 86 +12v permanent
- 30 +12v permanent
result: the relay don't want to close.
All my ground have been controlled with multimeter and are ok. I don't understand the problem
Something stange when i turn on ignition to start the relay don't close but when i release it i see the relay close and open quickly...
Any idea? Any opinion? i
Thank you for your welcome help.
- 87 to fuel pump
- 30 +12v permanent
i did this:
- 87 to fuel pump
- 86 +12v permanent
- 30 +12v permanent
