OK, just checking as those fuses might indicate something else. Obvious first step is to replace those fuses. If they blow straight away then that might indicate an electrical problem with the ecu. Replace them one at a time, S27 first as thats the ecu supply which should allow you to access the ecu.
Can't see how the headlights would have anything to do with the engine to be honest!
http://www.s2central.com/motronic_04_fuses_ABY.html
