ABY Timing Belt Renewal
This is a sticky topic.
  • spink
    • 4382
    Thats some tool,bet theres a few quid worth there.
    come to think of it i think martinjs made something like that.Will go round tomorrow and steal it!
    • Dan_s2_coupe
      • Aug 2006
      • 482
      Yeah i borrowed them from work, they are for the 5 cylinder T4 and for the LT
      i just pulled 1 and pushed the other was tight tho
      The thick one is the torque wench will go alot more than the required torque
      If you ever use a big torque wench dont pull down from above you as then it clicks over will nearly knock you out lol some kid when i was at collage done it. this one is ok only moves abit
        Its sorted now... Used a 3/4" socket set and a big swing bar and it just came off with no drama. There was none of the bending and springing you get with 1/2" tools - just amazing how much more rigid the big stuff is. Easy enough with the right tool. Relief.
        Paul
          Very quick update... Been quietly working away on these thru any spare time I found over the holidays.
          New timing belt fitted along with new crank pulley & bolts, tensioner and new water pump & bolts. Also renewed all the auxiliary belts.
          Getting the required 200Nm plus 180 degrees into that bottom pulley bolt requires some energy I have to say - and lots of trust in the locking tool and snub mount bracket...
          Hand cranked the engine a few times, spun it up on the starter (CMP off), then fired her up with no coolant just to give me the sanity check that all is well before getting on with everything else.
          Also renewed the cam cover gaskets, lambda probe, HT stubs and all the filters...
          I have numerous photos, copious notes and will post a full description in due course.
          Only issue I had was with the little M6 bolts that lock the belt tensioner down to the block. The most recent version of the ABY factory manual states 29Nm (twenty nine) torque for these bolts which I thought was wrong, but gently went for it anyway... Sheared one bolt clean off !!! But I was lucky where it sheared so I could tease it out again. I renewed them all (cut and filed some high tensile M6 bolts I had) and went for 20Nm which is called up in the AAN factory info. I used a lil thread lock on these for good measure as well as the big bottom bolt.
          Paul
          • DJones
            • Jun 2005
            • 2020
            Paul
            Paul you need one of these... locks all the i5's..
            • rj scotty
              • May 2006
              • 2195
              #21
              This locks via the fly wheel I presume ?
              But how do you fit it ?
              cheers
              rich
              BUT I DON'T WANT A NEW CAR!
              1995 S2 Avant, Volcano Black
              • DJones
                • Jun 2005
                • 2020
                cheers
                rich
                Take the starter motor out bolt it in place using the same bolts that hold the starter inn,,,, job done!!
                  cheers
                  rich
                  Just guessing... You take the starter motor off, lock the flywheel, apply 800NM to undo the bolt and bend the crank. (Thats why its supposed to be locked from the front.)
                  • rj scotty
                    • May 2006
                    • 2195
                    #24
                    I WANT ONE
                    next question(s):
                    Where ?
                    How much ?
                    cheers
                    rich
                    • rj scotty
                      • May 2006
                      • 2195
                      #25
                      Ahh I did not think of that
                      rich
                      • DJones
                        • Jun 2005
                        • 2020
                        I WANT ONE
                        next question(s):
                        Where ?
                        How much ?
                        cheers
                        rich
                        I made it, not sure if you can buy such a tool...
                        Its been borrowed on many occasion no bent cranks yet!! you wouldn't bend a cast crank with a spanner how ever large. It would shatter before it bent and none have yet...
                        If you lighten your front pulley... enough... or use an aluminium one you have no choice..
                        • rj scotty
                          • May 2006
                          • 2195
                          #27
                          Again a very good point
                          rich
                            #28
                            Djones has a clever alternative method which he lashed up. I'm not getting into the argument about crank bending etc..
                            There are plenty of folk on the forum with the correct factory locking tools. I was offered use of this 2084 tool by a kind member in Ireland- it has extra sections welded on to make it work with ABY pulleys. The more correct tool for ABY & AAN is the 3256. Both are available on eBay frequently for not ridiculous money. I also know a tool supplier in Germany who can get them for OK money.
                            Paul
                              Fair enough, if you dont have the original harmonic damper you'll need to find an alternative.
                              • S2 Ant
                                • 3682
                                Just as a heads up - the smaller tool on the left of the 3 in that picture didnt fit my ABY when i had one, it was about a pulley's thickness too short to fit - perhaps as my car had aircon?
                                Just in case people see them on the bay and wanted to pick one up
                                Ant
                                2011 Kawasaki Z1000
