Well you've got about ~50Nm more torque and ~50bhp more than when it left Ingolstadt so yes the difference is always 'noticeable' shall we say
Paul's ABY Home Fries
This is a sticky topic.
hi!
i have just send mine ecu to paul for some upgrade
have some questation: i have rs2 chamshafts and rs2 intercooler at home. will be there any positiv affect if i upgrade mine s2 with those parts and home fries? or is it better to have only stock car and home fries?Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
RS2 intercooler will definitely give some gains earned from lower air temp.
By all means try the RS2 camshafts if you like, but I have not a had a chance to run those on this software. Suspect you might lose some mid range and gain something at the top end.
I'm pretty confident you will be happy with the difference provided by the ECU software without playing around with camshafts ! However, it would be an interesting test if you have some objective way to capture data - like a g-meter or similar.
PaulPaul Nugent
As paul says, you won't be disapointed turnaround is usually pretty quick too Only trouble now is once you get that extra go it doesn't take long before you need more:mischeif:Ragusa Coupe gone!
I usually turn them round on the day they arrive as long as I have notice. Did one last night like that and I see there's a few more candidates lined up for the treatment !
PaulPaul Nugent
Yes - I'll get back to you on that... Should be viable enough.Paul Nugent
hello
just a quick question, found some chips in germany that says gains of, plus 81hp and plus 141Nm is this possible for the s2 3b???
sorry to loan this thread??japanischer industriabfall nein danke!!
www.rackeltrim.se Icelandic Division
No thats crazy... A generic upgrade on 3B or ABY is in 270-280bhp and 410-430Nm territory. Thats a useful gain of 50bhp and 50Nm for the ABY along with improved spool time etc etc.
The upgrade on 3B 'feels' better compared to stock chips as they have a very relaxed 309Nm of torque in factory trim so you are looking at potential gains of 120Nm for a 3B with GOOD chips... But there is just no way the stock turbo can flow the kind of air volume required for 230+81bhp.
PLEASE please please don't buy S2/RS2 chips on eBay unless you are absolutely certain that you know what you are buying. There are some god-awful ones out there.
Sure, at £250 a generic upgrade from me is a lot more than schlonky chips on eBay, but I have in excess of 50 happy customers out there... And 100 angry ones - no I'm kidding
PaulPaul Nugent
ok
thanks for the lesson, i will probebly contact you for a chip set...japanischer industriabfall nein danke!!
Pm
Calling Paul of S2Central, sent PM and hope you can let me have some info etc as requested on the homefries for my 3B Cq project and will give you some good press in Audi Driver too if they are as good as others have been stating on here. David Harrison1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remap
Originally posted by 20Vcqdriver View PostCalling Paul of S2Central, sent PM and hope you can let me have some info etc as requested on the homefries for my 3B Cq project and will give you some good press in Audi Driver too if they are as good as others have been stating on here. David Harrison
You'll also need a MAP sensor upgrade in the ECU.
