Best place to buy F5DPOR's
This is a sticky topic.
  • s2driveruk
    • 12696
    Pricing all over the shop online - any tips? Just seen £16+vat per plug
    Sure it wasnt that long ago I bought 5 for £35
    1992 3b S2 Coupe
  • JP
    • 1858
    Main dealer only imo. Less likely to get a duff batch.
    Alternativelly you could buy NGK BKR-7EIX. Which is a cheap alternative.
    UrS6 Stroker + HTA3586 =
    • madpugger
      • Sep 2007
      • 1901
      My dealer set at €85 have caused no end of damage when the core fell out one. New block req.
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • Nik0las
        • 1345
        • Country: Bulgaria
        I'm very unhappy with those. Brand new plugs and the car misfired on dyno runs. Now I'm with champion QC59C - very happy
        For such high price they're very poor made....
        • JP
          • 1858
          Take it back guess the dealer ones are as bad as everywhere else now
          • s2driveruk
            • 12696
            how can they be so poor - getting kicked round the stockroom or something???
            1992 3b S2 Coupe
            • K7ERG
              • 1711
              I have used these plug for years in a few setups and never had a issue.
              Last time i bought the F5 DPOR plugs think it was ebay.
              Craig
              Audi A6 AEL 5cyl Quattro breaking.
              Audi A5 3.0tdi Quattro Stage 2
              07947385043
              • K7ERG
                • 1711
                http://www.ebay.co.uk/itm/Bosch-Plat...item2311eba21c
                07947385043
                • K7ERG
                  • 1711
                  Ask for discount on postage.
                  07947385043
                  • prj
                    • Mar 2010
                    • 6308
                    Don't buy these plugs anymore. They moved their manufacturing into a chinese ghetto or something...
                    The porcelain bits break and fall into the cylinder, causing damage, brand new plugs misfire sometimes for no reason at all, etc.
                    I use FR5DP's from Volvos and I never had a problem with those.
                    • Thuppu
                      • 4115
                      Yes, FR5DP is actually one of the best choice to use with 1.8T coils. So If you have done a coilswap these will work great, and cost the half of the F5DP0R.
                      • K7ERG
                        • 1711
                        I stand corrected
                        07947385043
                        • prj
                          • Mar 2010
                          • 6308
                          Originally posted by K7ERG
                          I stand corrected
                          The problem happened fairly recently. Like they started getting worse 1 year ago or so.
                          It's like buying a lottery ticket nowadays. If you are lucky, all will be fine, if you are unlucky, you'll get engine damage because of broken porcelain.
                          • K7ERG
                            • 1711
                            http://www.ebay.co.uk/itm/1x-Bosch-P...item3371bc839d
                            07947385043
                            • Avantus
                              • Sep 2007
                              • 941
                              • Country: Belgium
                              So are the FR5DP's also suitable for the stock coils, or do you need the 1.8T coils?
                              Put new POR's 1year and a few months ago, so don't want te be running any risk.
