Originally posted by AndyP
View Post
Best place to buy F5DPOR's
This is a sticky topic.
I have bought two sets of bosch plugs in the past that where visually bad.
All in one set, and one in another.
The plug gap was obviously to large, and the electrode was misaligned.
The supplier took them back without question.
Problem is what do I replace them with. I have tried NGK with no success. Even after regaping they still misfired.
Has anyone used the champion QC59c, or the bosch FR5dp's .or frdtc
Maybe back to copper is the answer. I don't trust any at the moment.
There's nothing wrong with copper plugs. Yes you have to change them more regularly BUT they're considerably cheaper than iridium/platinum plugs & don't foul as easily.
FWIW, when you cross reference the standard Bosch plug to NGK it comes up as being PFR7B
These charts may be some use so you can choose for yourself:
Is it a 3B ? :
i just removed the non gapped ngk plugs that were already installed in my new S6 as the car spluttered when given it fully welly and replaced them with the gapped ngk plugs that were in my old S6:
result: no misfire and full thrust achieved as well as improved low down acceleration too!
Last edited by geneandbolly; 19 September 2015, 13:48.1997 Audi S6 - The Purple Helmet!
Originally posted by geneandbolly View Posti just removed the non gapped ngk plugs that were already installed in my new S6 as the car spluttered when given it fully welly and replaced them with the gapped ngk plugs that were in my old S6:
Are they copper ?
without dragging them back out i can't tell you, i'm afraid. they were the standard ngk replacement for the bosch ones, just re-gapped to 0.6mm
http://www.ngkpartfinder.co.uk/car_c...=S6&engine=2.2
Last edited by geneandbolly; 21 September 2015, 17:15.1997 Audi S6 - The Purple Helmet!
Just checked plugs in the green machine (ABY). Bosch F5DPOR fitted
Been reading through this lot and standard NGK for the ABY is PFR7B (http://www.ngkpartfinder.co.uk/car_c...0PLUGS&key=ABY) ........but in this thread PFR7Q , BKR-7EIX and BKR-8EIX are also mentioned?
So, what'll I fit?
Thanks in advance.
Engine is standard (for now).
John.
