Best place to buy F5DPOR's
This is a sticky topic.
I have bought two sets of bosch plugs in the past that where visually bad.
All in one set, and one in another.
The plug gap was obviously to large, and the electrode was misaligned.
The supplier took them back without question.
Problem is what do I replace them with. I have tried NGK with no success. Even after regaping they still misfired.
Has anyone used the champion QC59c, or the bosch FR5dp's .or frdtc
Maybe back to copper is the answer. I don't trust any at the moment.Comment
There's nothing wrong with copper plugs. Yes you have to change them more regularly BUT they're considerably cheaper than iridium/platinum plugs & don't foul as easily.
FWIW, when you cross reference the standard Bosch plug to NGK it comes up as being PFR7B
These charts may be some use so you can choose for yourself:
champion plugs.jpgngk plugs.jpgComment
and you'll have to re-gap the ngk plugs or they'll missfire at full thrust, captain!
1997 Audi S6 - The Purple Helmet!Comment
Just removed my POR bosch plugs and thankfully they're fine. Doubting putting same back in tho , at £50 also they're not cheap and worried if they fail it's all over.!!Comment
Try a set of a NGK copper plugs, gapped, and if it still misfires, one would think that it is something else rather than your plugs, presumably in your ignition set up ?
Is it a 3B ?
i just removed the non gapped ngk plugs that were already installed in my new S6 as the car spluttered when given it fully welly and replaced them with the gapped ngk plugs that were in my old S6:
result: no misfire and full thrust achieved as well as improved low down acceleration too!
Last edited by geneandbolly; 19 September 2015, 12:48.1997 Audi S6 - The Purple Helmet!Comment
0.6mm on ngk - i think that they come out of the box as 0.75mm but mike will confirm that for you . . . can't believe that a tiny adjustment like that can make a massive difference!!
Are they copper ?Comment
Last edited by geneandbolly; 21 September 2015, 16:15.1997 Audi S6 - The Purple Helmet!Comment
Just checked plugs in the green machine (ABY). Bosch F5DPOR fitted
Been reading through this lot and standard NGK for the ABY is PFR7B (http://www.ngkpartfinder.co.uk/car_c...0PLUGS&key=ABY) ........but in this thread PFR7Q , BKR-7EIX and BKR-8EIX are also mentioned?
So, what'll I fit?
Thanks in advance.
Engine is standard (for now).
John.Comment
Fit the NGK, John but you'll have to gap them. Mike knows the gap - I can't remember!!
0-200km/h 9sec
