Best place to buy F5DPOR's
This is a sticky topic.
  • #91
    What plugs for a chipped RS2 spec then? BK8EIX? What are the part numbers for the copper plugs?BKR8E
    • #92
      Ik used BKR7E up to my 515hp tune on ron98 fuel. After that at 590hp and 700hp on E85 i started to use the BKR8E
      1360kg/600Whp Avant 0-200km/h 9sec
      • #93
        Originally posted by V6quattro View Post
        ... i would use the BKR7E for a stock ABY.
        You mean the BKR7EIX ??.....or BKR7E
        Thanks, your patience is appreciated.
        • #94
          I mean the BKR7E plugs.
          • #95
            @ V6quattro.
            What NGK plugs do you reckon for a
            1. Chipped AAN ?
            and for a
            2. RS2+ spec AAN ?
            And what respective gaps ?
            Thanks.
            • #96
              Thanks, will get them tomorrow.
              • #97
                There is a good thread somewhere, which looked at various plug options. I concluded BKR7EIX was the best standard replacement and for running a moderately modified car (eg chipped). Will try and find it when I'm back at the laptop.
                0.6mm is the gap you want
                1995 Audi S2 Avant
                • #98
                  That sounds a pretty narrow gap to me? Maybe 'cause I'm used to thousands of an inch!!
                  Everyone out there running 0.6mm?
                  • #99
                    I'm running 0.7 on FSI coils. I know people who run 0.8 on FSI coils. No issues whatsoever.
                    Although I'm still stock for the moment this is what I run - NGK BCPR7ET, 0.7 gap, tri-electrode. It's NGK's alternative to Bosch FR5-DTC, even though Bosch's have 0.8 gap.
                    • I run 0.7mm gaps on BCR8ES plugs
                      (homefried ABY)
                      • Bkr7eix upto 400-450hp bkr8eix 450-650hp bkr9eix 600+
                        Gaps on high boost engines 1.8bar+ adviseable to run gaps lof 25thou/0.6mm (yes i know 25thou is a teensie weensie bit bigger) however with the **** uk pump fuel bigger gaps like the factory 0.7mm settings can start to missfire under high load.
                        Ngk plugs like bkr7e 8e etc.... nice cheap plugs but can break up/melt from heat and shock of turbo use.
                        As for any dual and tri groundstrap plugs you're asking for pre ignition issues on pump fuel. If it hasn't happened yet then consider yourself v. fortunate.
                        UrS6 Stroker + HTA3586 =
                        • That's interesting. I've been running these plugs for half a year, and have encountered no issues with pre-ignition. The plug heat index is the same as Bosch's F5DP0R. I must be very lucky on our 98 octane.
                          • 0.6mm on NGK plugs and no misfires on super unleaded . .
                            1997 Audi S6 - The Purple Helmet!
                            • Hi!
                              Some time has passed and I want some opinions about the Bosch FR5dp.
                              Something about they?
                              Thanks
                              photobucket SUCKS
                              • I am back on the Bosch plugs and no issues whatsoever - fantastic performance and no misfires at all . ..
