rs2 engine problem!(help)
Post your config or email it/pm it to me so I can have a look. It may be a lot of things from improper can alignment to poor enrichment etc... I didn't see the videos -
why do you say "RS2" and then say the engine is a 3B and not an ADU?
You have a serious miss on at least 2 cylinders. Could be plugs, coil packs, injectors, who knows.
Can't help you too much because of VEMS.
I know at the end it wouldn't start. With Motronic it would be because the Motronic wants > 13 RPM before it will trigger the fuel pump relay (which powers more than just the fuel pump). J17 Fuel pump relay info: http://forums.quattroworld.com/s4s6/msgs/22583.phtml Not sure if your VEMS is set up the same way.Leave a comment:
Finally i managed to run the engine of my car, however i got a problem that you can see when you watch the video. The car Works well when it runs at an idle but when i step on the gas it stops.the camshaft sensor and the crank sensor are new they are not old.
What would be the reason causing this problem in your opinion? After a long time effort and after managing to start the engine, facing this kind of problem bothers me lot.
I look forward hearing from you, need your help!!!
Motor: stock 3b
ecu : vems
Gearbox: stock
clutche &flywheel are below:
Tags: None
