S6 timing
Apart from being peeved with the car, you must be getting close at this stage.
The one saving grace to remember is that all of the things you've checked / replaced will stand to you once you nail the fault. The car once the current mystifying fault is found will be good for years.
You have my virtual support in your quest, ( for what it's worth ).
Ahh yes, so he did, hahaha
It's just the time to get there at the minute, I have so little free time at the minute!Comment
Hi,Apart from being peeved with the car, you must be getting close at this stage.
yes I guess I am. Seems at the minute as simple as; Get the load reading correct and it'll cure it.
And also, yes they are my thoughts exactly, the car is 20 years old and new sensors to do with the cars running HAVE ATO BE A GOOD THING!Comment
Yeh I quite agree! But I also can't overlook the fact that I have two MAF sensors that check out exactly as 'right' as each other, give identical load readings at idle (not checked one at wot) but one is over 1% difference AFR, going from 15.2:1 to 13.8:1.Comment
There does appear to be another member suffering from air escaping from the oil cap during leak testing although his symptoms are not identical. So have you replaced this in your ownership. If not, thats cheaper than a Maf to start with.
On the mafs. Of course we don't know for certain whether unmetered air is corrupting the afr if you see what I mean. In % terms its a massive difference in the load.Comment
The oil filler cap is NOT THE ISSUE. It is how the cam cover is being pressurized during boosting (or a boost leak test) that is the issue.RS2'd 93 UrS4 5 spd sedan
SO why would you change the oil cap needlessly then?
(I'm pretty sure that the new MAF is needless too but....)RS2'd 93 UrS4 5 spd sedan
Understood!
Substitution often works when you know for certain that the substitute is functioning correctly. The maf is the primary engine sensor its just unfortunate that the parts stash hasn't come up trumps on this occasion.
Lets hope it is just something as simple as that now.Comment
YOU need to PAY Dmitri (prj) to get involved. You're *not* going to get your load answer from us (amateur) sleuths. Contact Dmitri. Offer MONEY. Get him on the case. He's not going to help you for free, that is obvious.RS2'd 93 UrS4 5 spd sedan
