Hi all, I was advised to repost in this thread with a bit of advice I posted today; worth a shot as it worked for me.
If having issues (like I was) with intermittent stuttering at high revs >3000rpm, this is caused by the fuel pump cutting out to protect the engine: "limp mode". One reason for this can be a dirty MAF sensor. The sensor is easily removed by removing the jubilee clip and two bolts, then using a cotton bud and contact cleaner, gently clean the metallic sensing element inside the chamber. This was the definite cause of intermittent 'limping' which I didn't even know existed at the time. I thought I had an engine timing/misfiring problem. Luckily, it was an easy and free repair that even I managed; albeit after having the fuel filter, air filter, oil filter, engine oil and spark plugs changed at the garage
Take it easy, Grant
Take it easy, Grant
