boost lag and fuel economy question
  • hunker7
    • Mar 2014
    • 3487
    #151
    Can't decide between getting a second hand one or silicone one.
    If weather allows I will boost test tomorrow and check how it runs without lambda connected.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • Rikki Kitto
      • Feb 2010
      • 6276
      Get a new one a second hand one is as old as yours
      • hunker7
        • Mar 2014
        • 3487
        #153
        They're about £100 I'll leave it for now and get it running properly (as properly as I can). I have duck taped it pretty well so it won't have massive effect on performance.
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          #154
          Just unplugged lambda on my way home and didn't notice any change in the way car drives, might be running even slightly better. So I guess lambda it is.
          '93 Audi UrS4 Avant
            #155
            At last !
            Hopefully it does show a good improvement.
            Buy a Bosch one.
            • hunker7
              • Mar 2014
              • 3487
              #156
              Originally posted by macspring
              At last !
              Buy a Bosch one.
              I bought NGK as I never had any issues with them. I really hope this is the culprit and I can have a fully working S4 for once.
              '93 Audi UrS4 Avant
              • hunker7
                • Mar 2014
                • 3487
                #157
                Fitted new lambda and voila **** all changed.
                '93 Audi UrS4 Avant
                • Henkjan
                  • 1705
                  I had a low milage "universal" Denso lambda from my V6 which I fitted, didn't change a thing.
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Has you lamda got 3 wires or 4
                    • hunker7
                      • Mar 2014
                      • 3487
                      #160
                      It has 3 wires. But I'm taking back what I said, it has improved, I removed battery to nester ECU. But it still isn't 100% which takes me back to timing.
                      Atm it's set by a chopstick in first cylinder. Should I set it again but use the flywheel mark and ignore lower pulley mark?
                      '93 Audi UrS4 Avant
                      • hunker7
                        • Mar 2014
                        • 3487
                        #161
                        Originally posted by Henkjan
                        It was definately working as I had her running bang on for couple of days
                        '93 Audi UrS4 Avant
                          #162
                          Glad it worked out.
                          Maybe wait a few days / journeys for the ECU to 'relearn' itself.
                          I'd say time of the fylwheel mark as your bottom pulley's keyway is probably fractured and has slipped it's position slightly.
                          Sorry just kidding.
                          Run it for a few days, tbh, but that duct taped hose is not a good idea if you wan the car to run 100% 100% of the time. You have to help it to help you.
                          I appreciate a silicone one is best, but the dearer option. Even a tired oem one as a stop gap may be better option than the current duck tape. Just sayin.........
                          • hunker7
                            • Mar 2014
                            • 3487
                            #163
                            Don't you joke about slipping OK?
                            MAF hose is on my list but first she needs to run properly. Slight vacuum wouldnt affect it this much.
                            When I put timing using flywheel mark temperature was just under 88 degrees whereas now it's around 92 degrees and also, flywheel must be more accurate than lower pulley surely.
                            Fuel economy has improved and it feels quicker too now, so I will set timing again before I head back to Leeds
                            '93 Audi UrS4 Avant
                              #164
                              Agreed, such slipping is no joke for anyone tbh.
                              While my advices re the lambda was on the mark this time, I wish my advices were as good for my own cars.
                              Interested to hear your feedback after you get back from Leeds.
                              I know I sound like a whiney pain, but I think you're underestimating the significance of running a second rate hose and expecting perfection. These cars are hard enough to get to run right when you think you have everything in good condition.
                              Regards.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #165
                                Regards.
                                I'm at my brothers now so he will have to help me set it perfectly
                                I'll buy it eventually.
                                '93 Audi UrS4 Avant
