boost lag and fuel economy question
  • hunker7
    • Mar 2014
    • 3487
    #106
    Checked DV and ir holds vacuum ok.
    I moved timing belt as well.
    Also, checked PCV system and clip on the small one way valve wad loose so I did that up, and put new clips on few more vacuum lines. Noticed temperature is now just over 90 (88 on 51st channel on climate control panel) and I done see full boost in 3rd (3rd@4200 ish rpm max boost before)
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
      What does this mean? ^^
      Did you find your vagcom lead yet?
      • hunker7
        • Mar 2014
        • 3487
        #108
        Remember when you said floor it in 3rd@2000rpm and see when full boost is reached? And I said about 4200 rpm, now it won't go past 2.2/2.3.
        I did find it, and no errors.
        '93 Audi UrS4 Avant
          It gets weirder... You correct the timing and get less boost? Did you move the belt in the right direction? (sorry, clutching at straws..)
          • hunker7
            • Mar 2014
            • 3487
            #110
            Tell me about it. At one point seems it's better and then it seems it's worse/same.
            '93 Audi UrS4 Avant
              Do you have another FPR you can try?
              • hunker7
                • Mar 2014
                • 3487
                #112
                One I have is pretty much new, bought a Bosch unit.
                '93 Audi UrS4 Avant
                  Originally posted by Error404
                  Have you checked for a restriction yet?
                  • hunker7
                    • Mar 2014
                    • 3487
                    #114
                    I didn't no, as I need to get 17mm socket (forgot it in London)
                    '93 Audi UrS4 Avant
                    • hunker7
                      • Mar 2014
                      • 3487
                      #115
                      Taking out the downpipe bolt didn't go that well (sheared it) even though I was careful. Car still runs like a piece of ****. Seems like it runs worse than with timing supposedly out.
                      I don't think exhaust is blocked because when it was blocked on my V6 at one point car slowed down as in its not able to get rid of all the exhaust fumes. Nothing like this with the S4.
                      '93 Audi UrS4 Avant
                      • hunker7
                        • Mar 2014
                        • 3487
                        #116
                        Worth putting OEM chips back in?
                        '93 Audi UrS4 Avant
                          Maybe Worth a try..
                          Have you checked for leaks on the vac line to the ECU?
                          • hunker7
                            • Mar 2014
                            • 3487
                            #118
                            I'm literally out if ideas at this point.
                            '93 Audi UrS4 Avant
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Check, check and recheck I am just running down boost leaks after the car was mapped 3 months ago with no leaks, found 4 last week and am checking again on Saturday
                              • hunker7
                                • Mar 2014
                                • 3487
                                #120
                                Don't think it's a boost leak but I'll test it. All the sensors seem to be working, I will check TPS sensor.
                                BTW, couple of days ago I noticed car fails to pick up revs when I start it, if I rev it, it's all good.
                                '93 Audi UrS4 Avant
