Coil Packs Misfire
    10 designed for our engine, got the bulk discount from euro car parts.
    • S2sedan
      • Aug 2004
      • 189
      #77
      how much did you pay for those ???
      S2 Limo sold !!!
      M5 E34 with some mods in the garage
      sorry, but much happeir now !
        £630 inc vat and delivery
        • S2sedan
          • Aug 2004
          • 189
          #79
          so 63 pounds each ????
          S2 Limo sold !!!
            Yeah there abouts, I was quoted 67.85+vat and P&P on 5 before.
              Been trying to wire up my coil packs today and tired them in the car but I must have a wire in the wrong place and its a nightmare trying to find the problem. Can anyone provide a definitive set of pinouts for the connectors etc? need to get the car back on the road tommorow,
              ta
              • Doug_RS2
                • 3847
                #82
                I emailed some info to you Greg - It was too big to post here - i have 3 email addresses for you so I hope one gets to you.
                  Cheers doug, I appreciate it
                    Ive had a look at the diagrams last night. It doesnt quite solve my problem though since I dont know which cylinder is no 5 or no 1. Ive got the link to the SJM autotechnik site which shows the pinouts of the POS to the coils on the page here, ive checked those and they look fine. its the white connectors onto the bulkhead I need to check now.
                    What I need to work out is if the pin outs on the white connectors are in the same order as those on the POS?
                    • kwlw
                      • Sep 2004
                      • 1025
                      • Country: Lithuania
                      #85
                      http://www.sjmautotechnik.com/troubl...4_Ignition.htm
                      White connectors of the coils, are constant +12v as far I remember. Also at least on aan, there are cylinder numbers on the injectors. All connectors have numbers, and the pin missing on the apropriate connectors.
                      Hope this helps.
                      Sau
                        Ive had another read thru the wiring diagrams doug sent me and the sjm site and I think ive got it worked out. It looks like all 5 connections to the white connector go back to a 20Amp fuse. I'll take a look on the injectors.
                        @Kwlw does the picture on the SJM site match up with the right cylinder no for the corresponding coil?
                        I will have another go at checking my wiring this evening and hopefully will have the car up and running again.
                        • kwlw
                          • Sep 2004
                          • 1025
                          #87
                          I will post it in three posts. IMHO it is the clearest way I can describe .
                          1. Coil numbering according to VAG
                          2. End stages numbering according to VAG
                          3. Electrical schematics
                          • kwlw
                            • Sep 2004
                            • 1025
                            #88
                            Coils
                            Picture of coils
                            • kwlw
                              • Sep 2004
                              • 1025
                              #89
                              Picture of end stages
                              • kwlw
                                • Sep 2004
                                • 1025
                                #90
                                Ignition schema
                                Electrical schematics of the pictures above
