UR Quattro Set Up?
  • adam g
    • Feb 2007
    • 445
    Although you are focusing on electrics I still strongly recommend testing for an air leak. When I ran kjet I had no end of them when the hoses were getting old.
    Sent from my D5803 using Tapatalk
      Originally posted by Monkeymagic
      I get nothing from the plugs mate, well occasionally and I mean very occasionally get a faint spark but not from the electrodes..
      But you're getting a spark from the centre lead? The one from the coil to the dizzy? I thought that's what you were saying earlier..
      • Monkeymagic
        • Mar 2012
        • 3419
        Yes g28 counts flywheel teeth G4 reads the timing pin. Both checked as well as timing pin all working spot on. Air leaks affect fuelling as k jet is mechanical fuel injection. I should still be getting a spark. I will test rotor arm to see if it's going to ground.
        • Monkeymagic
          • Mar 2012
          • 3419
          Yes the spark from centre lead of LT is both strong and about 3 or so per second. It's the number 1 plug that gave a very little or no spark..
          • Monkeymagic
            • Mar 2012
            • 3419
            I even left LT lead on cap and left cap off the centre electrode was happily sparking away to the nearest earth. I'm suspecting the rotor arm at the mo. It was new but that doesn't mean it's ok. I have read a rmsimple test of holding the LT lead near the rotor arm and if the spark jumps to the rotor it is going to earth.
            • Tonybolony
              • Dec 2011
              • 636
              I have ( despite what restricted thinks of me) worked very methodically through the test procedures and everything checks out. I have a healthy and regular spark from the LT lead but nowt from number 1 spark plug. I'm not sure now if the Ecu isn't happy with one of the sensors or an actual mechanical fault. I will sit and read the other articles thank you Newsh.
              Sorry Steven, I don't want to appear pedantic, but I'm confused when you say you get a regular spark from the LT lead. Is not the LT lead the one feeding the Coil? Is that what you are referring to?
              If (as i believe) you're referring to the Coil to Dizzy cable (King Lead was what I was led to believe it was called, but that was years ago), then surely if you're getting a healthy & regular spark here, and no further, it's got to be down to the rotor (grounding the spark to the centre shaft internally), or the dizzy cap itself.
              The correct rotor for the WR has already been suggested, and I'm sure you have the right one with the wider contact edge, but could it be something as simple as the dizzy itself being just out of rotational position?
              If i remember rightly- some 10 years ago I had a similar issue with my own WR, and slowly rotating the dizzy cured the issue, and it didn't return.
              Just a thought, Buddy
              • Monkeymagic
                • Mar 2012
                • 3419
                Yes LT King lead etc. Dizzy cap is new and I have tried a spare. The timing marks are all aligned perfectly. I haven't tried another rotor arm yet. You know what it's like sometimes these faults screw your head. However the more I ponder I come back to rotor.. Cheers for all the advice guys..
                • Tonybolony
                  • Dec 2011
                  • 636
                  As I said Steven; I didn't want to appear pedantic, but aside all the quirky stuff that the WR has (wasn't it the worlds first car with a (albeit very basic by today's standards) engine ECU??), surely the basics of a dizzy still apply, ie if a spark is coming in, and not leaving where it should, it's either being lost to another cylinder (and as the injectors on the K-Jet spray 'Konstantly' (), then would you not hear the detonation?), or it's being lost to earth via the shaft?
                  I know there are sensors everywhere to control the spark, but looking at this from a Basics point of view- I find it hard to believe the fault is anywhere other than the dizzy.
                  Good Luck
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    That's kind of what I'm thinking know. Eg a simple mechanical fault . As I exhausted all checks that involve the ecu I can only fault the rotor or dizzy. I will report back once I have a new rotor. Keep everything crossed..!!!
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      I mean now...
                      • Tonybolony
                        • Dec 2011
                        • 636
                        When you get it sorted, WE NEED PHOTOS/VIDEOS
                          I'm not sure if I explained myself properly earlier.. If the ECU gets the TDC sensor on the flywheel but doesn't get the hall signal from the Dizzy it only sends one spark per revolution of the crank and this will occur at TDC on cyl 1.
                          If the ECU is getting the hall signal from the dizzy (and the TDC sensor on the flywheel) then you will get 5 sparks per 2 revs.
                          Your description of 3 or so sparks per second strongly suggests that all is well and you're losing the spark in the rotor or dizzy cap.
                          • twoqu
                            • Sep 2003
                            • 3103
                            #58
                            There is two different caps/rotors for the WR. The chassis break is at 85-E/85-F.
                            035 905 207A Cap 055 905 225B Rotor for up to E.
                            034 905 207B Cap 052 905 225C Rotor for F on. This rotor is listed as 10mm which appears to be the dizzy shaft diameter.
                            So perhaps this is just a mismatch between the components.
                            • Tonybolony
                              • Dec 2011
                              • 636
                              Soz, Newsh- I missed the point with you're original reply about the above
                              Anyway- how 'bout some photos/updates on your Ur as well
                                Correct rotor arm
