Although you are focusing on electrics I still strongly recommend testing for an air leak. When I ran kjet I had no end of them when the hoses were getting old.
Sent from my D5803 using Tapatalk
), then surely if you're getting a healthy & regular spark here, and no further, it's got to be down to the rotor (grounding the spark to the centre shaft internally), or the dizzy cap itself.
, but aside all the quirky stuff that the WR has (wasn't it the worlds first car with a (albeit very basic by today's standards) engine ECU??), surely the basics of a dizzy still apply, ie if a spark is coming in, and not leaving where it should, it's either being lost to another cylinder (and as the injectors on the K-Jet spray 'Konstantly' (
), then would you not hear the detonation?), or it's being lost to earth via the shaft?
