Well I am calling the plastic bit that the screws secures a drip tray!
Half the battle is identifying where the water comes in, so you are half way there.
This drip tray should sit on some gaskets that sort of surround the holes. Mine had detiorated but were not the source of a leak. Its possible that water is getting in around the cap and it then has a nice well to lay in as it wicks down the screw! Like John, I made some "washers" from the sealant and used them undeneath the metal washers. I then rolled a thin string of sealant and ran it round the cap. Bit of a fiddle but belt and braces. Pop the cap and see whether its got water in it. If its dry, its probably getting in underneath so you will have to remove it to attend to the problem!
Good luck!
Good luck!
Yup two more hidden behind the numberplate surround / reflector.
Was hoping for a p/n for the seals
This I may add with the tailgate open !
