034 Short Shift
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    #121
    i think that 4 washers, not 2 alloys.
    So the setup is :
    1) put alloy on the bottom
    2)little bit cut of both plastic ends
    3) mount new shift
    4)put 4 washers on studs
    5) tightened this
    6) cut off a holder off spring?
    Audi Coupe Quattro 2.3 20V
    • zefsider
      • Dec 2011
      • 138
      thats it....BUT cutting the spring ? Don't know why you have to do that ?
      • Tom_
        • Oct 2007
        • 1301
        #123
        not spring,but this "holder". And how much to cut?
        • DeS
          • 611
          • Country: Poland
          #124
          Cut the bush in one step. This will allow lever to move up and down and make shifting more easy.
          Sorry for replying so late, but I have some problems with main computer at home
          • Tom_
            • Oct 2007
            • 1301
            #125
            show me where....thx . I thought,that is plug n play and not bore,cut n play
            • zefsider
              • Dec 2011
              • 138
              ??? I did not cut he plastic thing and it still changes gear fine ....mine is the 5 speed gearbox, maybe cut it if you are doing the 6 speed box ? I don't know, but no problems at all after I fitted it , really nice feel to the shift now .
              • |CL|NIKI
                • Jun 2008
                • 380
                • Home: Bulgaria Current: United Kingdom
                #127
                DeS maybe will be better to make a DIY explanation + pic's for the 5 and 6 gearboxes...I will need some help too.
                Mine is here - looks very nice. Thanks again mate.
                Up for a good seller.
                800HP 800++Nm
                • Tom_
                  • Oct 2007
                  • 1301
                  #128
                  I think,that if i have a 5speed gearbox,i havent to cut a plastic bush,but now i am confused.... At 6 speed gearbox is recommended to cut that....
                  • M_GORDON
                    • Oct 2008
                    • 1295
                    • Home: Isle of Man Current: Vatican City State
                    #129
                    Hi.
                    We must cut for down the gearknob to put Reverse gear. Only on 6 gearboxes.
                    And see my pics
                    photobucket SUCKS
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      are there any of these still for sale Im after one!.
                      • DeS
                        • 611
                        • Country: Poland
                        #131
                        Right now, I have few of these on stock.
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          A forum member just up the road may have one. If not How much posted to uk?
                          • DeS
                            • 611
                            • Country: Poland
                            #133
                            It will be 66 Euros or 57 Pounds. Collection by meeting is ofcourse possible.
                            • Tom_
                              • Oct 2007
                              • 1301
                              #134
                              I have next problem. If its right,if the spring are fit on the shift ball and slides after the ball ? (u can see on the picture). Because a OEM shifter have a holder which hold spring up to ball (on the picture)
                              Or this is right?To slide after the ball
                              • DeS
                                • 611
                                • Country: Poland
                                #135
                                Tom, tommorow I will make you a picture how it should look like, please give ma a little bit more patience.
                                Did it now.
